          Spotless with a Single Stroke
            Stays Clean and Ready to Roll
            Seamless and Upgraded
Maneuverability
Roborock F25 Series
Play Video
Sticky, Even Hairy Mess?
 Make It No Mess.
99.99 %2
99.99 %2
Bacteria Removal Rate450
Cleaning Strokes3 / min
            20,000 Pa5
Suction Power
              >20 N4
Downward Cleaning Pressure
              <1mm
Edge-to-Edge Cleaning9
<1mm
Edge-to-Edge Cleaning960 min7
Battery Life under Eco Mode
410 sqm8(4,413 sqft)
Cleaning Area per Charge
Tangle Rate10
Cleaning Level
Dirt Level
*Available on Roborock F25 ALT and Roborock F25 ACE.
As you clean, the F25 series uses the DirTect module to detect the cleanliness level of the water, so it knows how much it should be self-cleaned, even before it is placed back in the dock. *
Moves as You Move
90 °C13
5 min
Fast Drying
99.99 %14
Multiple Stages
Separation System
99.99 %14
Multiple Stages
Separation System
            Voice Alert
Auto
Cleaning Rollers
Empty the dirty water tank
Auto
Cleaning Rollers
4.0kg
Dimensions (with dock)
330 * 316 * 1157
Dirty Water Tank
720ml
Clean Water Tank
870 ml
Battery Life 40min
(Eco Mode)
4.2kg
330 * 316 * 1157
Dirty Water Tank
720ml
Clean Water Tank
870 ml
Battery Life 60min
(Eco Mode)
DirTect Smart Sensor
Proactive Self-Washing
4.2kg
330 * 316 * 1157
Dirty Water Tank
720ml
Clean Water Tank
870 ml
Battery Life 60min
(Eco Mode)
Auto Detergent
Dispenser
4.7kg
352 * 316 * 1157
Dirty Water Tank
720ml
Detergent Tank
100 ml
Clean Water Tank
740 ml
Battery Life 60min
(Eco Mode)
Key Specs
4.0kg
330 * 316 * 1157
Dirty Water Tank
720ml
Clean Water Tank
870 ml
Battery Life 40min
(Eco Mode)
4.2kg
330 * 316 * 1157
Dirty Water Tank
720ml
Clean Water Tank
870 ml
Battery Life 60min
(Eco Mode)
4.2kg
330 * 316 * 1157
Dirty Water Tank
720ml
Clean Water Tank
870 ml
Battery Life 60min
(Eco Mode)
Auto Detergent
Dispenser
4.7kg
352 * 316 * 1157
Dirty Water Tank
720ml
Detergent Tank
100 ml
Clean Water Tank
740 ml
Battery Life 60min
(Eco Mode)
Auto Detergent
Dispenser
App Customization
4.7kg
352 * 316 * 1157
Dirty Water Tank
720ml
Detergent Tank
100 ml
Clean Water Tank
740 ml
Battery Life 60min
(Eco Mode)
13.Based on internal testing. The self-washing temperature refers to the temperature of the hot air outlet blowing over the hot water, not the temperature of the hot water itself. Actual results may vary depending on environmental factors.
