Auto-Empty Dock Pure Support
2700 Pa1 Suction Power
PreciSense® Precision LiDAR
Simultaneous Vacuum and Mop
3D Mapping
Custom Cleaning Routines
750 ml Large Dustbin
3D Mapping
Q7+
Simple Cleaning. Simpler Emptying
Play Video
3D Mapping
Roborock Q7 combines Roborock's proven technologies to create a robot that vacuums and mops effectively, is very easy to use, and is suitable for everyone.
Clear dirt trapped in your carpets and lift dust from your floors with a maximum suction power of 2700Pa1. Automatic carpet boost turns suction to maximum when a carpet is detected, for more effective cleaning.
Clean often, empty rarely with the Auto-Empty Dock Pure. It empties your robot automatically into its 2.5 L dustbag, every clean, for up to 7 weeks2. When the bag is full, it can be swapped out in seconds. The dustbag is also an effective air filter, tested to filter 99.7% of pollen as small as 0.3 microns3, helping your air clean.
A long-lasting all-rubber brush powerfully agitates carpets to release more dirt. Its fast rotation sends dust into the vacuum airflow, while its rubber material is strongly resistant to hair tangles. It can move across multiple panes, keeping it close to the ground for more effective cleaning.
Vacuum and mop simultaneously to capture fine dirt that vacuuming alone might miss.
Maximum Mopping Range
Dustbin Capacity
Water Tank Capacity
Powered by its high-capacity 5200 mAh Li-ion battery, Q7 offers long-lasting cleaning that easily tackles most homes. Able to climb 2 cm (0.8 in) obstacles5, it climbs easily over thresholds and onto carpets.
Maximum Vacuuming Range
Maximum Runtime
Roborock's PreciSense® LiDAR navigation system is the brains behind your robot, creating maps that power a suite of useful features. All controlled in the Roborock app.
Take control of your robot, start cleanups, send it to tackle specific rooms, and more with just the power of your voice. Amazon Alexa, Google Home, and Apple Siri Shortcuts are supported.
Have confidence that your Q7 can wander safely around your home. The Sensient sensor array includes a suite of sensors, including cliff sensors, accelerometers, bumpers, and more. It will avoid rolling off of steps, getting trapped, or slamming into your walls.
An E11 rated8 washable filter traps particulates inside your robot. It is washable for a longer life.
Q7+ vs Q7
2700 Pa Suction Power
3D Mapping
3D Mapping
1. Based on internal testing carried out by the manufacturer with a full battery using max mode according to IEC 62885-2:2016 / 5.8 standards.
2. Actual results may vary according to the home environment.
3. Based on testing carried out by an independent lab according to ISO/TS 11155-1-2001 and PT-22-000-100650 standards.
4. Based on internal testing carried out on hard floors with a full water tank, full battery, and low water flow. Actual results may vary, depending on the room characteristics. Range is an estimate based on the assumption that 20% of the area is covered by furniture and will not need to be mopped.
5. Without a mopping system attached.
6. Based on internal testing carried out by the manufacturer in Quiet mode on hard floors with a full battery and with no mop system attached. Actual results may vary according to the home environment.
7. Compared to Q7’s Clean&Mapping Mode.
8. Tested by an independent third party according to EN 1822-1:2019 standards.
