Roborock S7 Max Ultra - For those who don’t compromise | Roborock Global Official Store
S7 Max Ultra
For those who don’t compromise.
The S7 Max Ultra offers a complete hands-free cleaning experience without compromising any features, such as the RockDock Ultra all-in-one docking system, 5500 Pa HyperForce suction, VibraRise mopping system, and Reactive Tech obstacle avoidance. In other words, the S7 Max Ultra combines all of the best features into one powerful device.
play video
Available in Black and White
Q7-Max Q7-Max
Q7-Max Q7-Max
A Higher Level of Convenience
· RockDock Ultra
· 30% Faster Charging1
Q7-Max Q7-Max
Long-lasting Quality
· 180 min Runtime
· Durable All-Rubber Brush
Q7-Max Q7-Max
Flagship Cleaning Performance
· 5,500 Pa2 HyperForce Suction
· VibraRise Mopping System
Q7-Max Q7-Max
Easy-to-use Intelligence
· Reactive Tech Obstacle Avoidance
· Customizable App Features
Q7-Max Q7-Max
· RockDock Ultra
Q7-Max Q7-Max
Q7-Max Q7-Max
Q7-Max Q7-Max
· 180 min Runtime
RockDock Ultra
One Dock to Rule Them All
Experience hands-free cleaning with the RockDock Ultra for a new level of convenience, leaving your home spotless and smelling fresh all the time.
  • Dries the mop and bottom of the dock to prevent unpleasant odors.
  • No need to wash the mop manually after use.
  • Allows for up to 7 weeks3 without emptying.
    Q7-Max
  • Fills water tank automatically for a mopping range up to 300 sqm(3230sqft)4.
  • Makes maintenance easy by automatically cleaning the bottom of the dock.
Q7-Max Q7-Max
Self-Drying
Q7-Max Q7-Max
Self-Washing
Q7-Max Q7-Max
Self-Emptying
Q7-Max Q7-Max
Self-Refilling
Q7-Max Q7-Max
Self-Cleaning
Q7-Max Q7-Max
Q7-Max Q7-Max
Q7-Max Q7-Max
30%
Faster
Charging
Morning
Night
Q7-Max
Off-peak Charging
Quickly resume cleaning by charging 30% faster1 than before and get the most from low energy prices by charging during off-peak hours. It also plays its part in helping the environment.
5,500 Pa
5,500 Pa
5,500 Pa
Ultra-level Suction Power
Say goodbye to dirt and dust from floors and carpets. Power has been enhanced to 5,500 Pa2 HyperForce suction of power and the upgraded floating brush stays closed to uneven floors, to catch all the mess in your home.
VibraRise
Mopping System
Enhanced Cleanliness
Removes dried stains 30% more effectively than traditional robot mops with sonic scrubbing at 3,000 times per minute, and combined with consistently high downward pressure, leaving less dirt behind.
Makes cleaning convenient with multiple modes to tackle any mess.
Vac & Mop
Mop
Vacuum
3,000
times/min5
30%
more effective6
Auto Mop Lifting7 for the Ultimate Clean
Can tell the difference between carpet and hard floors, raising and lowering the mop as need to mopping where its not supposed to.
Worry Less with
Reactive Tech
Obstacle Avoidance
Worry Less with
Reactive Tech
Obstacle Avoidance
Q7-Max
Detects objects on the floor so you don’t have to move anything before starting a clean-up. It can also suggest No-Go Zones automatically, to prevent your robot vacuum getting stuck in tight spots, or falling down the stairs accidentally.
Q7-Max
Q7-Max
Q7-Max Q7-Max
PreciSense LiDAR Navigation
The Best Route, Everytime
Q7-Max
The brain behind your robot can create detailed maps to plan the optimal route for cleaning your home.
Q7-Max Q7-Max
Quick Mapping
On its first run, your robot will quickly create a detailed map of your home without you needing to do anything, so you can start cleaning ASAP.
Q7-Max Q7-Max
3D Mapping
3D Mapping lets you build your house virtually. With the ability to add furniture, you can create the most detailed map of your home, ensuring that you get the best possible clean.
Q7-Max Q7-Max
Multi-level Mapping System
Multi-level mapping automatically recognizes distinct levels of your home. All you have to do is put the robot down. No additional docks or app identification are needed with up to four floors supported.
Easy-to-use App features
Custom Cleaning Routines
  • Q7-Max
  • Q7-Max
  • Q7-Max
  • Q7-Max
  • Q7-Max
  • Q7-Max
  • Q7-Max
  • Q7-Max
Q7-Max
Q7-Max
  • For Carpets
  • For Hardwood Floors
  • One-Tap Routines
  • Pin&Go
  • Activate Carpet Boost and Deep mode to clean carpets twice in one task for better cleaning performance.
  • Let the robot vacuum clean the floor along its direction so the floor seams can be cleaned along the route and minimize scraping against them.
  • Clean your house whenever and wherever you like with custom cleaning schedules, regularly or on demand.
  • Simply tap your phone and let the S7 Max Ultra get to work, giving you a precise clean every time.
Q7-Max
Q7-Max
For Carpets
Q7-Max
Q7-Max
For Hardwood Floors
Q7-Max
Q7-Max
One-Tap Routines
Q7-Max
Q7-Max
Pin&Go
Long-Lasting Quality
Cleans On and On
Q7-Max Q7-Max
5,200mAh Large Battery
Clean your home in one go, with up to 180 minutes of runtime.
Q7-Max Q7-Max
Easily cleans up hair without tangling for minimum maintenance.
Q7-Max Q7-Max
Large 200ml Water Tank
Capable of supporting the entire home8 without water refilling.
Q7-Max Q7-Max
Start the vacuum.
Voice Control
Cleaning can happen from any room with Amazon Alexa, Google Home, and Siri Shortcuts, which let you control your robot with the power of your voice.
Adaptive Route Algorithms
ScratchSafe Wheels and Brushes
Child Lock
Sensient Sensor Array
Washable E11 Rated Air Filter
S7 Max Ultra Dimensions
Robot Vacuum
350*353*96.5 mm
422*504*420 mm
Q7-Max
S7 Max Ultra S7 MaxV Ultra
Q7-Max-Ultra Q7-Max
Auto Mop Drying
Auto Mop Washing
Auto Mop Washing
Auto Tank Refilling
Auto Tank Refilling
5,500Pa HyperForce Suction
5,100Pa HyperForce Suction
ReactiveAI 2.0 Obstacle Avoidance
S7 Max Ultra   vs   S7 MaxV Ultra
S7 Max Ultra
S7 MaxV Ultra
Auto Mop Drying
Auto Mop Washing
Auto Tank Refilling
Auto Mop Washing
Auto Tank Refilling
1. Compared to Roborock S7. Based on internal testing carried out by the manufacturer. Actual results may vary according to the home environment.
2. Based on internal testing carried out by the manufacturer according to IEC 62885-2:2021/5.11 standards, using Max+ mode with a full battery. Actual results may vary according to the home environment.
3. Actual emptying interval will depend on use habits and environmental factors.
4. Based on internal testing carried out on hard floors with a full clean water tank in the Empty Wash Fill Dock using default mode. Actual results may vary, depending on the room characteristics.
5. Based on internal testing carried out by the manufacturer. The term relates to the integrated mop module being able to be driven to produce high-speed reciprocating vibration of up to 3000 times/min, i.e. up to a frequency of 50Hz which is within a “sonic” range (20 to 20,000Hz).
6. Based on internal testing carried out by the manufacturer. Stains used for testing include coffee (dried for two hours and 24 hours), juice (dried for 24 hours), cola (dried for 24 hours) and mud (dried for 2 hours).
7. Based on internal testing carried out by the manufacturer, the mop module can be lifted up to 5mm.
8. Based on internal testing carried out on hard floors with a full electronic water tank in the robot using default mode. Actual emptying interval will depend on use habits and environmental factors.
