Roborock S7 Pro Ultra - Vacuum. Mop. Wash. Automagically. | Roborock Global Official Store
S7 Pro Ultra
subscribe
Fully AutomatedEmpty Wash Fill Dock
5100 Pa1Suction Power
VibraRiseMopping System
3DMapping
Vacuum more. Mop More. While emptying less, cleaning less, and doing less. The Roborock S7 Pro Ultra combines the S7 Pro robot and the acclaimed Roborock Empty Wash Fill Dock to unleash another level of floor cleaning automation.
One Dock to Rule Them All
The Empty Wash Fill dock is Roborock’s most advanced dock to date, unleashing a world of new conveniences for those who demand the cleanest of floors.
Self-Refilling
Refills the robot water tank during the cleanup for a mopping range of up to 300sqm.2
Self-Washing
A unique washing system washes robot mop during cleanup and when finished.
600 rpm high-speed scrubbing
Self-Cleaning
Self-cleaning design cleans itself, too, for even easier maintenance.
Self-Emptying
Auto-dustbin emptying means up to 7 weeks3 without changing a bag.
Self-Refilling
Self-Washing
Self-Emptying
Self-Cleaning
Fast Charging
30% Faster
Recharge 30% faster4 and get back to cleaning sooner.
Off-Peak Charging Supported
Get the most of low energy prices by charging your vacuum during off-peak hours. Save money while still keeping your robot charged up and ready to clean, and do your bit for the environment.
2500 Pa
More Suction? Done and Dusted
The suction power has been cranked up. All the way up. From a maximum of 2500 Pa on the Roborock S7 all the way to 5100 Pa1 on the S7 Pro Ultra. That’s more than double the power. Fire up the Max+ mode, and all that power is yours.
Upgraded Floating Brush
A durable all-rubber brush effectively resists hair tangles. It stays closer to even uneven floors through its multi-plane floating mechanism.
VibraRise Mopping System
Mop with the Power of Sound5
3,000times/min30%more effective
3,000 times/min
30% more effective
Experience robot mopping like never before, with VibraRise sonic vibration technology that scrubs your floors not hundreds, but thousands of times per minute. 3,000 times per minute to be exact. Combined with consistently high pressure6, the VibraRise® system removes dried stains 30% more effectively7 than traditional robot mops and leaves less dirt behind than spinning mops.
Ready to Rise Up
Got carpets? Like freshly mopped floors? Perfect. Intelligent mop lifting means when a carpet is detected, the mop is lifted out the way8. Now you can get mopped floors and vacuumed carpets in one single clean9. No setting No-Mop-Zones. No swapping parts. No hassle. Just pure convenience.
When you want to mop, you don’t want to have to find and attach a mop cloth. Let alone the hassle of swapping your robot’s side brushes for mops. With VibraRise, you don’t have to. With a tap on your phone, you can switch from vacuuming to mopping and back as often as you like.
Vac & Mop
Mop
Vacuum
Keep Clean Areas Clean
If you’ve got beautifully cleaned living room floors but your kitchen needs to be mopped, do you want that kitchen dirt dragged across your living room? No. Using VibraRise, you can mop your kitchen and only your kitchen. Afterward, the robot will lift the mop and cruise back to its dock, leaving floors spotless.
3D
Matrix
2D
3D
Matrix
2D
Bed
Your Virtual Home
Recreate your home, along with all your furniture and floor types, right in the Roborock app. Automatically. When mapping is done, you can add your furniture, including beds, sofas, tables, and more. Need to clean around the bed after a lazy breakfast? Just tap on your bed.
With your home recreated, you can view it in 3D with 3D Mapping and navigate it virtually with a Matrix map10.
Bed
Your Virtual Home
Tailored Room Cleaning
Customize cleaning to match the needs of each room, and S7 Pro Ultra will automatically adapt as it cleans, from high scrubbing intensity and maximum suction in the kitchen to quiet mode and no mopping outside the nursery and everything in between.
One-Tap Routines
Do you cook a lot? Find yourself always turning up the suction and sending the robot to the kitchen? Do your pets randomly knock food out of their bowls? Set a Routine for these frequent but ad-hoc tasks then trigger the cleanup with a tap. You can also add schedules to any routine you set.
Voice Control
Amazon Alexa, Google Home and Siri Shortcuts support lets you command your robot with the power of your voice.
Product Album
Product Album
PreciSense® LiDAR Navigation
Adaptive Route Algorithms
3D Mapping Support
Sensient® Sensor Array
Washable E11 Rated Air Filter
ScratchSafe Wheels and Brushes
Child Lock
Off-Peak Charging
1. Based on internal testing carried out by the manufacturer according to IEC 62885-2:2016 / 5.8 standards, using Max+ mode with a full battery. Actual results may vary according to the home environment.
2. Based on internal testing carried out on hard floors with a full clean water tank in the Empty Wash Fill Dock using default mode. Actual results may vary, depending on the room characteristics.
3. Actual emptying interval will depend on use habits and environmental factors.
4. Compared to previous Roborock docks.
5. Based on internal testing carried out by the manufacturer. The term relates to the integrated mop module being able to be driven to produce high-speed reciprocating vibration of up to 3000 times/min, i.e. up to a frequency of 50Hz which is within a “sonic” range (20 to 20,000Hz).
6. Based on internal testing carried out by the manufacturer, the pressure of the mop on the floor is more than 6N.
7. Based on internal testing carried out by the manufacturer. Stains used for testing include coffee (dried for two hours and 24 hours), juice (dried for 24 hours), cola (dried for 24 hours) and mud (dried for 2 hours).
8. Based on internal testing carried out by the manufacturer, the mop module can be lifted up to 5mm.
9. Automatic mop lifting is only suitable for low-pile carpets no higher than 4mm.
10. Matrix Map is currently available on iPhone 12 Pro, iPhone 12 Pro Max, iPhone 13 Pro, iPhone 13 Pro Max, iPhone 14 Pro and iPhone 14 Pro Max only.
