Roborock S7+ Sonic Mopping Robot Vacuum with Auto-Empty Dock. | Roborock Global Official Store
Roborock S7+ performance, meet convenience
Mop with the Power of Sound1
Experience robot mopping like never before, with VibraRise sonic vibration technology that scrubs your floors up to 3,000 times per minute.
mop scrubs
3,000times/min
water tank
300ml
  • Ready to Rise Up
    Got carpets? Like freshly mopped floors? Perfect. Intelligent mop lifting means when a carpet is detected, the mop is lifted out of the way2. Now you can get mopped floors and vacuumed carpets in one single clean3.
    Learn More
    get mopped floors and vacuumed carpets in one single clean with roborock s7+
  • Intense Hyperforce Suction
    Be the scourge of dust, with 2500Pa4 of HyperForce suction power that leaves dirt nowhere to hide. Not in cracks, not in carpets, nowhere you can reach.
    2500Pa of HyperForce suction power leaves dirt hard to hide in cracks and carpets
Learn More
箭头-fit-ebk (1) Created with Sketch.
Learn More about Roborock S7+
Roborock auto-empty dock eliminates pollutants for six weeks without emptying
Six weeks5 Without Emptying
Get all this cleaning power, but not all the emptying. Able to hold up to six weeks of dust, it makes keeping your floors clean easier than ever.
Eliminate Pollutants
Keep allergens locked up with an onboard filtration system that captures 99.99% of particles as small as 0.3 microns6. When it's time to empty, a swift pull of the dustbag seals it shut, ready for instant disposal.
Roborock S7+ captures 99.99% of pollutants and with a dustbag ready for instant disposal
*Allergy Care certification only applies when used with the dust bag.
Learn More
Check with your retailer for available colors.
1.
Based on internal testing carried out by the manufacturer. The term relates to the integrated mop module being able to be driven to produce high-speed reciprocating vibration of up to 3000 times/min, i.e. up to a frequency of 50Hz which is within a “sonic” range (20 to 20.000Hz).
2.
3.
Suitable for low-pile carpets no higher than 4mm.
4.
Based on internal testing carried out by the manufacturer according to IEC 62885-2:2016 / 5.8 standards.
5.
Actual emptying interval will depend on use habits and environmental factors.
6.
Tested by TÜV Rheinland according to IEC 62885-2:2016 standards.
VibraRise Mopping System
3,000times/min30%more effective
3,000 times/min
30% more effective
Experience robot mopping like never before, with VibraRise sonic vibration technology that scrubs your floors not hundreds, but thousands of times per minute. 3,000 times per minute to be exact. Combined with consistently high pressure, the VibraRise system removes dried stains 30% more effectively than traditional robot mops and leaves less dirt behind than spinning mops.
Ready to Rise Up
When you want to mop, you don’t want to have to find and attach a mop cloth. Let alone the hassle of swapping your robot’s side brushes for mops. With VibraRise, you don’t have to. With a tap on your phone, you can switch from vacuuming to mopping and back as often as you like.
Vac & Mop
Mop
Vacuum
Keep Clean Areas Clean
If you’ve got beautifully cleaned living room floors but your kitchen needs to be mopped, do you want that kitchen dirt dragged across your living room? No. Using VibraRise, you can mop your kitchen and only your kitchen. Afterward, the robot will lift the mop and cruise back to its dock, leaving floors spotless.
1.The VibraRise mopping system is available on the S7, S7 Pro Ultra and S7 MaxV.
