Customize Your Cleaning
Customize wash and dry programs with adjustable settings like water temperature, rinse times, dryness levels, and more, for impeccable laundry care.
Rolling with Confidence
Play Video
Clean Deeper Than You Imagine
Gentle and Powerful Drying for Different Clothing Types
Say Goodbye to Lint and Maintenance Hassles
30 Days Maintenance-Free Experience1 with Optimal Detergent Usage
Roborock Zeo One keeps your laundry dry and fresh for a full 24 hours
Stay Informed and Never Miss a Laundry Cycle
Zeo One makes taking care of your laundry effortless, worry-free, and time-saving, especially for people with a busy lifestyle, allowing you to free up valuable time to cherish moments.
Washer
Dryer
Space Saving
Zeo One effortlessly tackles even the toughest laundry stains, from stubborn red wine stains3 to ketchup, coffee, lipstick, and more.
Enjoy ultra cleanliness with anti-allergy and hygienic healthier cleaning results. Zeo One removes bacteria, mites, pet dander, pollen, and allergens, making it perfect for families with pets4.
Discover the power of Zeo-cycle™ drying technology, inspired by zeolite, which safeguards your clothes from shrinkage and damage while providing a brilliantly shiny finish without extreme heat.
Unlike traditional drying technology, Zeo-cycle™ drying technology works by effectively and efficiently capturing moisture from damp clothes without extreme heat thanks to zeolite’s super water vapor absorption capacity.
Because of zeolite's unique structure, it possesses a strong absorption capacity. The total surface area of zeolite in Zeo-cycle™ for water vapor absorption measures 288,000 square meters10, equivalent to 41,143 times its own area11. With the assistance of strong airflow, the entire surface area can be rapidly utilized in a minute, without requiring extreme heat, further enhancing the efficiency of drying clothes.
*Based on internal testing carried out by the manufacturer using theRoborock Zeo One module
Zeo-cycle™ is developed with a unique double air circulation path:
The drying air path continuously circulates to absorb the humid air in the drum to zeolite. The dry air is then blown into the drum to continue dehumidifying the clothes.
The regeneration air path performs dehumidification treatment on the zeolite, reducing it to a dry state, and as a result, this restores the water absorption capacity of the zeolite.
Did you know that drying clothes at high temperatures might not necessarily be better? Traditional condensation drying technology typically uses temperatures exceeding 80 degrees, or even 100 degrees. Such high temperatures can wear down or weaken fiber strength, causing irreversible damage to clothing, especially wool and silk. With Zeo-cycle™, you won’t have to worry about the shrinkage, deformation or discoloration.
The ideal washing and drying temperature for woollen sweaters is between 30-40 degrees. With Zeo One's wool washing and drying mode, you can rest assured that the temperature is stabilized within this controllable range12, ensuring that your delicate garments are well taken care of.
Auto Dosing
Get the Perfect Clean Every Time
Automatically dispenses detergent based on the weight of the clothes, so you don’t have to manually add detergent. You can also customize the dosage through the Roborock App for personalized care.
30 Days
Maintenance-Free6
580mL
Detergent
420mL
Softener
Forget damp clothes left in the machine—Roborock Zeo One's Laundry Aftercare uses air circulation to keep laundry dry and fresh for 24 hours, ensuring garments stay in perfect condition.
24
*The laundry aftercare feature needs to be manualy activated in the Roborock App
Drum Clean
Spotless Drum for Impeccable Clothing Care
Effortlessly cleans the drum inside and out for a hassle-free washing experience. Receive automatic reminders through the Roborock app for maintenance9.
Automatic Load Detection
Save Time, Save Energy
Automatically adjusts the amount of water and drying time according to the weight of the clothes, saving energy and time, while thoroughly washing and drying your clothing.
DD motor
Enhanced Performance, Minimized Concerns
Experience enhanced washing performance and improved durability with the belt-less design of the DD motor, guaranteeing superior and long-lasting results.
Zeo One Dimensions
595 x 850 x 660 mm
1. Based on internal testing carried out by the manufacturer. Estimated based on the load of a three-member family and a washing frequency of once every two days. Individual results may vary.
2. Based on internal testing carried out by the manufacturer. The Quick (Wash & Dry) program takes just 1 hour to wash and dry loads of up to 1kg. Actual results may vary according to the fabric.
3. Certified under rule IEC 60456-2022, certified No. 4840123157301 by TÜV SÜD.
4. Certified under rule GCN CCB GR 060CS, certified No. Z2GCN 118006 0025 by TÜV SÜD.
5. Please notice, lint refers to the lint from fabric, instead of the cat hair or dog hair.
6. Based on internal testing carried out by the manufacturer. Estimated based on the load of a three-member family and a washing frequency of once every two days. Individual results may vary.
7. Please notice actual washing/drying time may change according to the amount of laundry.
8. Please notice starting time can be set within 24 hours.
9. App reminder will be triggered after washing and drying 30 times.
10. Based on internal testing carried out by the manufacturer.
11. Based on internal testing carried out by the manufacturer.
12. Based on internal testing carried out by the manufacturer.
