HyperForce Suction Power 1
Deeper Cleaning, Where It Matters Most.
Up to 13,000 Pa
Dual Anti-Tangle System
VibraRise 2.0 Mopping
System
Auto Lifting Mopping
System
Roborock Q10 Max(+) / Q10V(+)
Roborock Q10 Pro(+) / Q10P(+)
ReactiveTech Obstacle
Avoidance
PreciSense LiDAR
Navigation
Self-Emptying Dock
Flexible App Control
Available Options
Roborock Q10 Max / Q10 Pro / Q10V / Q10P
Roborock Q10 Max+ / Q10 Pro+ / Q10V+ / Q10P+
Impressive HyperForce Suction Power
Root Out Hair From
Crevices and Carpets
Suction Power
Root Out Hair
From Crevices and Carpets
With up to 13,000 Pa suction, this powerful system is built to lift hair and debris from floor crevices and deep within carpets.
Fewer Tangle. Fewer Trouble.
Dual Anti-Tangle
Design
JawScrapers Comb
Anti-Tangle Main Brush
Hair Tangling on Side Brush 2
Removes Dust You
Hardly See
VibraRise 2.0 Mopping System
The VibraRise 2.0 Vibrating Mop System uses advanced vibration technology to tackle stubborn stains with ease. It efficiently lifts tough dirt and grime, leaving your floors spotless.
3000 times/min
Vibration Frequency3
8mm
Mopping Module Lifting3
Dual-Zone
Active Vibrating with Reduced Water Stain
Auto-Lifting Mopping System
The Auto-Lifting Mopping System automatically adjusts to carpets, providing a thorough clean with ease. Enjoy efficient, effortless mopping for consistently spotless results.
8mm
Ready to Avoid
Troubles, Every
Time
Powered by structured light, this advanced system effortlessly detects and navigates around obstacles, even in cluttered rooms with items scattered across the floor.4
PreciSense LiDAR Navigation
Learn, Navigate,
Remember
RockDock Plus
Handles Dirty
Work for You
Experience hassle-free cleaning convenience with the RockDock Plus. The large dust bag lets you clean for up to 7-10 weeks without emptying5, making it ideal for families with pets and reducing allergens.6
Tap, Tap, Clean
Temporary Cleaning
Temporary Cleaning
Auto Boost on Carpet
High-Intensity Mopping
Cleans Along Floor Direction
Robot Vacuum
Robot Vacuum
Support for Alexa and Google Home
5200mAh Battery Capacity
Customizable Cleaning Modes
Off-Peak Charging
1. Based on Roborock internal testing under Max+ mode with a full battery according to IEC 62885-2:2021/5.11 standards. The maximum suction power varies among different models. Actual results may vary depending on usage conditions.
2. Based on testing carried out by TÜV Rheinland. For anti-hair entanglement in different modes, the certification no. is CN251UKF 001. The pet hair tangle rate is 0%, while short human hair tangle rate is 0.063%. Actual results may vary depending on usage conditions.
4. Based on Roborock internal testing. Actual results may vary depending on usage conditions.
