Roborock Zeo X
Designed to Be Iconic. Built to Care.
banner banner
Roborock Zeo X: Where Performance Meets Design
Iconic Design, Seamless Fit.
At just 594mm deep (without door), it fits effortlessly into narrow spaces—without compromising on capacity. The ultra-thin body is complemented by a fully integrated seamless door, blending perfectly into modern interiors.
Invisible Until You Touch It
bg bg bg bg
ui ui ui ui
GloScreen blends the control panel into the design with refined simplicity. Its expansive glass surface stays hidden when not in use, then lights up with responsive, full-touch control when activated
Background Background
Trusted care for fabrics in every cycle.
Double-Certified Drying for Premium Wool Care
With Dual Woolmark Green Certification, enjoy professional-grade wool care in both washing and drying at home.
The dedicated wool program can nurture and protect your wool like hand wash, reducing shrinkage, deformation, and pilling, while restoring your garments' soft, fluffy shape and texture.
Wool Care Wool Care
Zeo-cycle: Revolutionizing Fabric Care
Gentle Drying, Smarter Care
Powered by Zeo-cycle drying technology, Roborock Zeo X keeps drying temperatures low—around 50°C for most fabrics and approximately 37°C for delicate materials like wool and silk1.
Clothes come out dry, soft, and protected thanks to dual airflow and low-heat drying, offering better care and improved efficiency.
Roborock FineFoam: Refined Washing
Rapid Foaming, Powerful Cleaning
Roborock Zeo X delivers an elevated washing experience with Roborock FineFoam technology.
Developed in-house, Roborock FineFoam generates ultra-dense microfoam that penetrates deep into fabrics, lifting dirt more effectively while remaining gentle.
By maximizing detergent activation and minimizing friction, it delivers a powerful clean even at low temperatures, helping clothes stay cleaner, softer, and newer for longer.
RR Seafarer: Intelligent Washing & Drying Algorithm
Adaptive. Accurate. Intelligent.
RR Seafarer intelligently adapts to every load, adjusting water flow, detergent, drum motion, and drying temperature in real-time.
With deep integration of Zeo-cycle drying technology and smart NTC sensors, it supports optimal cleaning, precise temperature control, and gentle fabric care, making every wash and dry automatic for greater peace of mind.
Smart Dosing System
Intelligence That Shows in Every Drop.
Roborock’s Smart Dosing System calculates the optimal amount of detergent and softener based on the weight of each load, maximizing cleaning power while reducing waste.
Smart Dosing
bg bg
30 Days
Maintenance-Free2
400 ml
Detergent & Softener Capacity
Control Bar Control Bar
Prefer full control?
Fine-tune your settings anytime in the Roborock App.
Precisely dissolves stubborn stains at the optimal heat.
Right Temperature, Right Stain
Independently certified by TÜV, the Heavy Duty3 programs use controlled temperature increases to target tough stains—red wine, lipstick, coffee, and ketchup—without compromising garment care.
bg bg
Comprehensive Hygiene, Inside and Out
Beyond Clean: Hygiene-Centered Care
Anti-allergen and Sanitize programs target deep-seated dirt and invisible irritants with lab-level precision.
Stats Background Stats Background
99.99%4
Bacterial Removal Rate
99%5
Allergen Removal Rate
99%6
Mite Removal Rate
tuv
Beyond the wash, a suite of intelligent features—including targeted door gasket spraying, a hygienic door seal, air fresh and drum clean—work together to protect both fabric and health, cycle after cycle.
Door Gasket Spray
Door Gasket Spray Cleaning
Air Fresh
Air Fresh & Drum Clean
Hygienic Door
Hygienic Door Seal
All-in-One App Experiences
App Background
Up to 24-hour Continuous Refresh
Keeps clothes fresh, soft, and wrinkle-free for up to 24 hours—automatically maintains ideal airflow to protect your laundry until you return.
*The laundry aftercare feature needs to be manually activated in the Roborock App.
blue texture blue texture
Stay Alerted and in Control
Stay updated with your laundry cycle — connect with the Roborock App to get real-time notifications and stay informed when your laundry is done!
Stay Alerted
Full Control Full Control
Take full control of your laundry with the Roborock App—from remote starts7 and voice prompts8 to customizing wash temperatures, rinse cycles, and dryness levels.
Explore 309smart modes, set schedules, and effortlessly manage all your Roborock devices in one unified space.
Smart Modes
Medium mode icon Auto
Sanitize mode icon Quick
Down mode icon Eco 40-60
Silk mode icon Silk
Rinse spin mode icon Down
Quick wash mode icon Air Refresh
Wool mode icon Anti-allergen
Spin mode icon Sanitize
Baby care mode icon Intensive
Anti allergy mode icon Heavy Duty
Drum clean mode icon Baby Care
Bedding mode icon Sportswear
Night mode icon Bedding
New clothes mode icon Underwear
Sports mode icon Season
and more...
Smart Modes
*Please note that the mobile app interface may change with updates, and the displayed interface is for reference only; the actual operating interface may differ.
Crafted for Comfort
Comfort Card 1
Interior Light
Comfort Card 2
Power Outage Memory
Comfort Card 3
Child Lock
Comfort Card 4
Pause and Add
* If the water level after pausing is too high to safely open the door, additional clothing cannot be added midway through the cycle.
center
Key Specs
Roborock Zeo X
Roborock Zeo X
Washer Dryer
595*631*850 mm
Stay Tuned!
*Images and videos are for illustration purposes only and may not exactly represent the product.
1. Based on internal testing carried out by the manufacturer. Actual temperatures may vary depending on environmental factors.
2. Based on internal testing carried out by the manufacturer. Estimated based on the load of a three-member family and a washing frequency of once every two days. Individual results may vary.
3. Certified No.4840125644400 by TÜV SÜD, based on testing on Washing using Heavy Duty mode with 60℃ hot water. Actual results may vary depending on environmental factors.
4. Certified No.Z2GCN1270030008 by TÜV SÜD, based on testing on Washing using Sanitize mode, over 99.99% of Escherichia coli, Staphylococcus aureus, Candida albicans are effectively removed. Actual results may vary depending on environmental factors.
5. Certified No.Z2GCN1270030008 by TÜV SÜD, based on testing on cat dander, dog dander, and pollen using Anti-Allergen mode with 90℃ hot water, over 99% of allergens are effectively removed. Actual results may vary depending on environmental factors.
6. Certified No.Z2GCN1270030008 by TÜV SÜD, based on testing on Washing using Sanitize mode, over 99% of mites are effectively removed. Actual results may vary depending on environmental factors.
7. Remote start must be manually enabled on the product control panel before use.
8. Voice prompts refer to audible notifications from the machine, not voice control features.
9. The number of wash and dry programs may vary by country or region. Some models may support fewer than 30 programs. Please refer to local sales information for accurate details.
