              289*289*848mm
289*289*848mm
262*262*843mm
293*250*1146mm
293*250*1146mm
293*250*1146mm
1. Tested by TÜV Rheinland based on the IEC 62885-4:2020/5.8 standard. Tested without any accessories, in MAX mode with a full battery, and using testing equipment with a diameter of 10 mm. Actual results may vary depending on usage conditions. Test report number: CN253JHD001.
2. For use within a home environment only. Actual results may vary depending on usage conditions.
4. Based on internal testing carried out by the manufacturer. Actual emptying intervals may vary depending on cleanliness conditions.
5. Based on testing carried out by SGS. Effectively removes 99% of Staphylococcus aureus and Escherichia coli. Test report number: SHFT250200007571, SHFT250200007471. Actual results may vary depending on usage conditions.
6. Based on Roborock internal testing with a fully charged battery in ECO mode using the 2-in-1 crevice brush. Actual runtime may vary under specific conditions or when using different accessories.
7. Refers to Roborock's previous cordless stick vacuum cleaner models. Results are based on Roborock internal testing. Actual results may vary depending on usage conditions.
8. Certified NO.PT/25/GEN/0112 by SGS. Actual results may vary according to the home environment.
9. Based on Roborock internal testing. Actual results may vary depending on usage conditions.
10. Tested by TÜV Rheinland based on ASTM F1977-22 standard. Tested in MAX mode for capturing particles of 0.3~5 μm diameter. Actual results may vary depending on usage conditions. 5-stage filtration system includes cyclone filtration, a metal mesh, a multi-cyclone component, a sponge filter, and a HEPA filter. Test report number: CN253JHD001.
11. Certified NO.PT/25/GEN/0111 by SGS. Actual results may vary according to the home environment.
12. Based on Roborock internal testing. Actual results may vary depending on usage conditions.
13. Actual results may vary depending on usage conditions.
14. Tested by TÜV Rheinland based on the IEC 62885-4:2020/5.8 standard. Tested without any accessories, in MAX mode with a full battery, and using testing equipment with a diameter of 10 mm. Actual results may vary depending on usage conditions. Test report number: CN25D3NM001.
15. Based on Roborock internal testing with a fully charged battery in ECO mode using the 2-in-1 crevice brush. Actual runtime may vary under specific conditions or when using different accessories.
16. Certified NO.PT/25/GEN/0190 by SGS. Actual results may vary according to the home environment.
17. Tested by TÜV Rheinland based on ASTM F1977-22 standard. Tested in MAX mode for capturing particles of 0.3~5 μm diameter. Actual results may vary depending on usage conditions. 5-stage filtration system includes cyclone filtration, a metal mesh, a multi-cyclone component, a sponge filter, and a HEPA filter. Test report number: CN25D3NM001.
18. Certified NO.PT/25/GEN/0194 by SGS. Actual results may vary according to the home environment.
19. Actual results may vary depending on usage conditions.
20. Based on Roborock internal testing. Actual results may vary depending on usage conditions.
21. Based on internal testing carried out by the manufacturer. Actual emptying intervals may vary depending on cleanliness conditions.
22. Based on testing carried out by SGS. Effectively removes 99% of Staphylococcus aureus and Escherichia coli. Test report number: SHFT250400016571, SHFT250400016572. Actual results may vary depending on usage conditions.
23. Tested by TÜV Rheinland based on the IEC 62885-4:2020/5.8 standard. Tested without any accessories, in MAX mode with a full battery, and using testing equipment with a diameter of 10 mm. Actual results may vary depending on usage conditions. Test report number: CN25LG2F001.
24. Based on Roborock internal testing with a fully charged battery in ECO mode using the 2-in-1 crevice brush. Actual runtime may vary under specific conditions or when using different accessories.
25. Certified NO.PT/25/GEN/0216/1 by SGS. Actual results may vary according to the home environment.
26. Tested by TÜV Rheinland based on ASTM F1977-22 standard. Tested in MAX mode for capturing particles of 0.3~5 μm diameter. Actual results may vary depending on usage conditions. 5-stage filtration system includes cyclone filtration, a metal mesh, a multi-cyclone component, a sponge filter, and a HEPA filter. Test report number: CN25LG2F001.
27. Certified NO.PT/25/GEN/0215 by SGS. Actual results may vary according to the home environment.
28. Actual results may vary depending on usage conditions.
