Roborock Qrevo Curv Series
Qrevo Curv Series
Power, Gracefully Delivered.
Find the Right Model for You
Find the
Right Model for You
  • Qrevo CurvX
  • Qrevo Curv
  • More Models
Roborock Qrevo CurvX
7.98 cm Ultra-Slim Design
Crafted to Clean Hidden Dust
22,000Pa HyperForce Suction1
Captures the Toughest Debris, Deep or Stubborn
Industry-First2 AdaptiLift Chassis
Elevates to Overcome Barriers with Ease
Multifunctional Dock 3.0 Thermo+
80°C Hot Water3 for Truly Clean Mops
Dual Anti-Tangle System
Minimized Tangles, Maximized Clean
Detects and Avoids, No Pre-Tidying Needed
No more unreachable spots under sofas and cabinets! The Roborock Qrevo CurvX— the slimmest Roborock yet4—effortlessly glides beneath furniture, capturing hidden dust and delivering a deeper, more thorough clean.
100% Success Rate
Cleaning in Spaces ≥7.98cm High5
In Open Spaces
Under Low Furniture
The LiDAR sensor stays elevated, providing 360° panoramic scanning to map your home with pinpoint accuracy and chart the most efficient cleaning route.
The LiDAR sensor retracts automatically, shifting to a 100° rear field of view—precision-tuned for tight spaces. This ensures smooth, accurate navigation, even in the hardest-to-reach areas.
Built for Precision and Reliability
The Upward Range Finder accurately measures overhead clearance, ensuring the LiDAR retracts or rises at the right moment for smooth, uninterrupted navigation.
The Top Contact Sensor detects overhead obstacles, preventing collisions and surface scratches for enhanced protection.
Built to last, the system undergoes rigorous testing to withstand tens of thousands of cycles6, delivering long-lasting, reliable performance.
AdaptiLift Chassis
The AdaptiLift Chassis brings a new level of versatility, allowing the robot to lift its entire chassis or adjust individual sections—front, rear, left, or right—based on the terrain. Whether tackling high thresholds or effortlessly maneuvering around furniture legs, it adapts seamlessly to your home's layout, enabling smooth, uninterrupted cleaning.
4cm Max.
Double-Layer Threshold Crossing7
Lift the Chassis
for Higher-Pile Carpets Cleaning
Prevent Getting Stuck
Discover Roborock's revolutionary dual anti-tangle system, with a main and side brush designed to handle everything from pet fur to 40cm-long hair. Enjoy tangle-free, hassle-free cleaning with no constant brush maintenance needed.
DuoDivide Main Brush
Hair Tangling Rate8
Hair Removal Rate9
Roborock Qrevo Curv Series Roborock Qrevo Curv Series
FlexiArm Arc Side Brush
Hair Tangling Rate10
22,000 Pa HyperForce Suction
Master Every Cleaning Challenge
With powerful 22,000 Pa HyperForce suction1, the Roborock Qrevo CurvX takes on the toughest cleaning challenges—from deep carpets to stubborn floor gaps—ensuring your home remains impeccably spotless.
FlexiArm Technology
Roborock's exclusive FlexiArm Arc Side Brush and Edge Mopping System deliver exceptional cleaning coverage, eliminating blind spots and ensuring no dirt is left behind.
Edge and Corner Coverage11
0mm
Along the Edge and Corner11
Enhanced Spinning Mops
The upgraded dual mops, rotating with up to 12N of downward pressure12 and warm water, lift and remove stubborn stains with ease, giving your floors a flawless finish.
12N Max.
Downward Mopping Pressure12
200RPM
Spinning Speed13
17mm Max.
Mop Lifting14
Liftable Brush and Mops
Low-Pile Carpet Cleaning / Vacuum Mode
Higher-Pile Carpet Cleaning
Mop Mode
Mops lift automatically to keep carpets or floors dry.
Mops and chassis lift together to keep carpets dry and prevent long fibers from blocking the suction port, ensuring a thorough deep clean.
The main brush lifts to stay dry and clean, preventing moisture buildup and keeping dirt and liquid separate.
Mop Mode
The Roborock Qrevo CurvX’s sleek, rounded dock enhances your home’s elegance, seamlessly blending into your living space while also serving as a highly functional cleaning companion.
80°C Hot Water3
The Multifunctional Dock 3.0 Thermo+ uses 80°C hot water3 to dissolve stubborn stains and grease, ensuring your mops are thoroughly cleaned and hygienic with every use.
99.99 %
Bacteria Removal Rate15
80°C Hot Water
Dock Self-Cleaning3
The dock base stays hygienic with up to 80°C hot water and the self-cleaning module, reducing manual maintenance.
Intelligent Dirt Detection
for Re-wash & Re-mop
45°C Warm Air Drying16
Dries the mops and dock base thoroughly with 45°C of warm air, preventing the growth of mold and unpleasant odors.
Warm Water Auto-Refilling
Allows for up to 65 days without manual emptying.17
Detachable Dock Base
With structured light and an RGB camera, the robot intelligently detects and avoids 108 types of objects18, seamlessly navigating around obstacles in both well-lit and dark spaces—no need to clear your floor beforehand.
108Types
of objects Recognizable
Tap, Tap, Clean
Roborock SmartPlan 2.0
Haven’t cleaned in a while? Deep clean boost. Kitchen? Mop re-wash before moving on. Roborock SmartPlan 2.0 customizes your cleaning based on your habits, room types, and floor materials for efficient cleaning tailored to your home.
Automatically deep cleans rooms that have not been cleaned for a long time
Lowers power and reduces noise during Do-Not-Disturb periods
Re-washes the mops right after cleaning kitchens and bathrooms or after a second mopping pass
Pet-Friendly
Because Your
Furry Friends
Deserve the Best
Video Call
Automatic Pet Recognition
Pet Snaps
Search for the Pet
Say “Hello Rocky”
for Help
  • "Clean here"
  • "Clean the kitchen"
  • "Just vacuum"
Matter Protocol
Embrace the Future
of Smart Living
Works Great with
Third-Party Voice Control
Launcher Widgets
Apple Watch App
350*352*79.8 mm
450*450*450 mm
Roborock Qrevo Curv
Featuring the DuoDivide Main Brush and FlexiArm Arc Side Brush for tangle-free cleaning.
Smoothly clears thresholds up to 4cm7 for seamless movement.
18,500 Pa HyperForce Suction1
Powerful cleaning that captures even the finest particles.
FlexiArm Technology
With the extendable side brush and mop for precision cleaning in every nook and cranny.
Enhanced 75°C hot water19 mop washing for a deep, hygienic clean of your mops and floors.
Roborock Qrevo Curv
352*347*103 mm
450*450*450 mm
Roborock Qrevo CurvC
Roborock Qrevo Curv S5X/5A1/5XC
Equipped with the DuoDivide Main Brush and FlexiArm Arc Side Brush, ensuring tangle-free cleaning.
Powerful HyperForce Suction
Delivers unmatched suction power for a deep and effective clean.
*Suction power values may vary by country or region. Please refer to information from your purchase channel for accurate details.
FlexiArm Technology
Features an extendable side brush and mop for precise cleaning in every corner.
Intelligently utilizes 75°C hot water19 to re-wash and re-mop for spotless floors.
352*352*98 mm
450*450*450 mm
352*352*98 mm
450*450*450 mm
Roborock Qrevo Curv 5A1
352*352*98 mm
450*450*450 mm
Roborock Qrevo Curv 5XC
352*352*98 mm
450*450*450 mm
STAY TUNED IN!
1. Based on internal testing carried out by the manufacturer according to IEC 62885-2:2021/5.11 standards, using Max+ mode with a full battery. Actual results may vary depending on environmental factors.
2. Roborock was the first in the robot vacuum industry to mass-produce a product featuring a liftable chassis system with three-wheel control, officially launching this technology in Q3 2024.
3. Based on internal testing carried out by the manufacturer, the water at the clean water dispensers of the base can be heated up to 80°C under standard room temperature. The actual temperature will vary due to environmental factors.
4. Based on research conducted by Roborock, as of April 2025, the Roborock Qrevo CurvX is the thinnest model among Roborock's vacuum robots.
8. Certified No.PT/24/GEN/0453/2 by SGS. Actual results may vary according to the home environment.
9. Certified No.PT/24/GEN/0454/3 by SGS. Actual results may vary according to the home environment.
10. Certified No.PT/24/GEN/0455/2 by SGS. Actual results may vary according to the home environment.
11. Certified No.0217010051 by TÜV Rheinland. Actual coverage and distance may vary according to the home environment.
12. Based on internal testing carried out by the manufacturer, the maximum downward mopping pressure is achieved with the Deep Cleaning for Heavy Dirt or Stains function, which needs to be manually enabled in the Roborock app. Actual results may vary depending on environmental factors.
13. Based on internal testing carried out by the manufacturer, when selecting extreme water flow in custom mode, the mops can spin at a maximum speed of 200 rpm. Actual results may vary depending on environmental factors.
14. Based on internal testing carried out by the manufacturer, the mop modules can be lifted up to 17mm away from the ground when the chassis is lifted.
15. Based on testing carried out by TÜV Rheinland on Staphylococcus aureus and Escherichia coli under default self-cleaning mode, over 99.99% of bacteria on the spinning mops are effectively removed. Certification ID: 0000088029. Actual results may vary according to the home environment.
18. Based on internal testing carried out by the manufacturer, the robot vacuum can see and bypass objects down to as small as 5cm wide and 3cm tall. Recognition accuracy may vary depending on environmental factors.
19. Based on internal testing carried out by the manufacturer, the water at the clean water dispensers of the base can be heated up to 75°C under standard room temperature. The actual temperature will vary due to environmental factors.
