Roborock Q7 Series
Roborock Q7 Series
Everyday Cleaning Made Reliable.
Q7 Series
Roborock Q7 Series
Up to 13,000 Pa
HyperForce Suction Power1
Roborock Q7 Series
Dual Anti-Tangle System
Roborock Q7 Series
Three Levels of
Water Flow
Roborock Q7 Series
PreciSense LiDAR
Navigation
Roborock Q7 Series
Self-Emptying Dock
Roborock Q7 Series
Flexible App Control
Available Options
 Roborock Q7 Pro Max / Q7 Pro / Q7T / Q7B
 Roborock Q7 Pro Max+ / Q7T+ / Q7B+
Impressive HyperForce Suction Power
Root Out Hair From
Crevices and Carpets
Suction Power
Root Out Hair
From Crevices and Carpets
Roborock Q7 Series
With an impressive suction power, this powerful system is built to lift hair and debris from floor crevices and deep within carpets.
Roborock Q7 Pro Max(+)
13,000 Pa
Roborock Q7 Pro / Q7T(+)
10,000 Pa
Roborock Q7B(+)
8,000 Pa
Fewer Tangle. Fewer Trouble.
Dual Anti-Tangle
Design
Roborock Q7 Series
Q7 Series
JawScrapers Comb
Anti-Tangle Main Brush
Hair Tangling on Side Brush 2
Consistent Water Flow Mopping
Consistent Water
Flow Mopping
Removes Dust You
Hardly See
Roborock Q7 Series
3 Levels
Water Flow Options
Detachable Mop Design
For Versatile Cleaning Needs
Roborock Q7 Series
Anti Scale Design
Built-in nonhazardous3 descalers bag prevent scale formation and protect pipes from clogging for up to 3 years4.
Anti Scale Design Anti Scale Design
Roborock Q7 Series
PreciSense LiDAR Navigation
Learn, Navigate,
Remember
Roborock Q7 Series
Roborock Q7 Series
RockDock Plus
Handles Dirty
Work for You
Q7 Series
Experience hassle-free cleaning convenience with the RockDock Plus. The large dust bag lets you clean for up to 7-9 weeks without emptying5, making it ideal for families with pets and reducing allergens.6
Q7 Series
Tap, Tap, Clean
Roborock Q7 Series
Q7 Series
Temporary Cleaning
Temporary Cleaning
Q7 Series
Auto Boost on Carpet
Q7 Series
High-Intensity Mopping
Q7 Series
Cleans Along Floor Direction
Q7 Series
Temporary Cleaning
Temporary Cleaning
Q7 Series
Q7 Series
Q7 Series
Robot Vacuum
325 * 325 * 99 mm
160 * 70 * 101 mm
Roborock Q7 Pro Max / Q7 Pro / Q7T / Q7B Dimensions
Robot Vacuum
325 * 325 * 99 mm
212 * 178 * 259 mm
Roborock Q7 Pro Max+ / Q7T+ / Q7B+ Dimensions
  • Customizable Cleaning Modes
  • Off-Peak Charging
  • Child Lock
STAY TUNED IN!
1. Based on Roborock internal testing under Max+ mode with a full battery according to IEC 62885-2:2021/5.11 standards. The maximum suction power varies among different models. Actual results may vary depending on usage conditions.
2. Based on testing carried out by TÜV Rheinland. For anti-hair entanglement in different modes, the certification no. is CN25I41V 001. The pet hair tangle rate is 0%, while short human hair tangle rate is 0.063% Actual results may vary depending on usage conditions.
