Images and videos are for illustration purposes only and may not exactly represent the product. The app interface is subject to change without notice.
1.
Based on internal testing of the digital motor under specific conditions. Actual results may vary depending on product configuration and usage conditions.
2.
Based on internal testing by the manufacturer, under test conditions where the first threshold height does not exceed 4.5 cm, the gap depth between the two thresholds is greater than 12 cm and does not exceed 14 cm, and the second threshold height does not exceed 4.3 cm, the robot is capable of crossing double-layer thresholds with a combined height of up to 8.8 cm. Actual performance may vary depending on environmental conditions and actual user usage.
3.
Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors.
4.
Based on internal testing carried out by the manufacturer. The mop adopts a Protruding-Fiber Design with elastic support, allowing the mop fibers to reach and clean along edges while preventing scratching the walls. Actual results may vary depending on environmental factors.
5.
Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors. Boosted mopping pressure result is derived from the comparison with Saros 10.
6.
Based on internal testing conducted by the manufacturer, compared with previous Roborock vibrating robot vacuum cleaners. Actual results may vary depending on environmental factors.
7.
8.
9.
10.
11.
This feature is powered by Roborock’s AdaptiLift Chassis—the industry’s first mass-produced liftable chassis system with three-wheel control, launched in Q3 2024. The dynamic carpet-cleaning capability was officially introduced in Q3 2025.
12.
Based on Roborock internal testing using Max+ mode. Compared to the performance on the 2cm long-pile carpets of previous Roborock vacuum robots. Actual results may vary according to the home environment.
13.
The body height of the robot vacuum is 7.98 cm. Due to slight vertical flexibility in the front structural components, the robot may achieve limited passive compression when entering low-clearance spaces, allowing access down to 7.95 cm. However, please note that scraping may occur. Actual performance may vary depending on environmental conditions.
14.
Based on research conducted by Roborock, as of November 2025, the Saros 20 Sonic is the thinnest model among Roborock's vacuum robots.
15.
16.
Based on internal testing conducted by the manufacturer using side brush for edge and inside-corner sweeping performance. Actual coverage and distance may vary depending on the home environment.
17.
18.
Based on internal testing carried out by the manufacturer. 'Each cycle' refers to the robot’s sweep-then-mop process for a specific area during a cleaning operation. Actual results may vary depending on environmental factors.
19.
Based on internal testing carried out by the manufacturer. The water at the clean water dispensers of the dock can be heated up to 100°C (212°F) under standard atmospheric pressure (1 atm, 101.3 kPa) at room temperature. Actual temperatures may vary depending on environmental conditions such as altitude and atmospheric pressure.
20.
Based on testing carried out by TÜV Rheinland on Escherichia coli and Staphylococcus aureus under default self-cleaning mode, over 99.99% of bacteria on the mop are effectively removed. Certification ID: 0000087672. Actual results may vary according to the home environment.
21.
Based on internal testing carried out by the manufacturer, the air at the base’s outlet during drying can be heated up to 55°C under standard room temperature. Actual temperatures may vary due to environmental factors.
22.
23.
24.
Based on internal testing carried out by the manufacturer, the robot vacuum can see and bypass objects down to as small as 3 cm wide and 3 cm tall. Recognition accuracy may vary depending on environmental factors.
25.
These carpet cleaning settings must be manually enabled and selected in the Roborock app. This feature is applicable to household carpets with pile heights of 3 cm or below, which covers the majority of carpets used in typical homes.
