Roborock F25 Pro Turbo Combo
Your upgraded smart 5-in-1 system.
HyperScrub On-Tap Deep Scrub Cleaning
No more hand-scrubbing dried-on stains.
Powerful Interchangeable Cordless Stick Vacuum
Clean anywhere, anytime.
JawScrapers Anti-Tangle Structure
Zero hair tangles¹⁴. No more manual cleanups.
All-In-One High-Temperature Self-Cleaning and Drying
Stays clean and ready for the next use.
SlideTech 2.0 Power-Enhanced Wheels
Seamless, upgraded maneuverability.
FlatReach 2.0 Lay-Flat Cleaning
180° full-flat design for under-furniture cleaning.
App and Voice Alerts
Stay updated, stay in control.
Tick, Tack, Switch.
One Core “Beats” for All
With a detachable power unit compatible with both bodies and three interchangeable brush heads, the machine seamlessly transforms into a wet-and-dry vacuum, a cordless stick vacuum, or a dust mite controller.
>99.99%
Bacteria Removal Rate¹
>99.99%
Mite Removal Rate²
Not Just the Floor,
But Everywhere
Not Just the Floor,
But Everywhere
Wet-and-Dry Vacuum Cleaner
Mops away both wet and dry waste.
Captures 99.99% of particles with whole-machine filtration.³
2-in-1 Crevice Tool
Designed for furniture gaps and window edges.
High-Reach Cleaning
Suctioning dust from high household spaces with an extension wand.
Motorized Mattress Brush
Meticulous care tailored for dust-mite sufferers²
One Pass, Total Clean
Trigger. Power. Spotless.
Introducing Roborock adaptive HyperScrub scrubbing technology, engineered for demanding messes. Hold the trigger to activate Scrubbing Mode and dynamically boost water delivery, suction power, and roller speed.
Built to break down stuck-on messes, dried spills, and heavy kitchen grubby⁴, deep cleaning power activates exactly when you need it most.
Comprehensive Improvement
245%
Increased Water Delivery⁵
24%
Higher Scrubbing Density⁶
36%
Enhanced Suction Performance⁷
Turbo Deep Scrub Cleaning-
Certified 0 Damage to Soild Wood Floors⁸
Certified by TÜV SÜD: In a 60-minute test on solid wood flooring with deep scrubbing activated, the surface showed no swelling, warping, or cracking—delivering powerful cleaning with complete floor safety.
Spend less time cleaning and more time living. With 25,000 Pa suction⁹ and a 550 RPM¹⁰ cleaning frequency, the Roborock F25 Pro Turbo Combo delivers spotless results in one glide.
>99.99%
  • 20 N¹¹
    Downward Cleaning Pressure
  • 550 RPM¹⁰
    Cleaning Strokes/min
  • 25,000 Pa⁹
    Suction Power
With a 60-minute battery life under ECO Mode, it ensures uninterrupted cleaning sessions, covering up to 460 sqm (4,951 sqft)¹³ before needing a recharge.
  • 60 min
    Battery Life on a Single Charge¹²
  • Up to 460 sqm (4,951 sqft)
    Cleaning Area per Charge¹³
JawScrapers Anti-Tangle Design
Zero Hair Tangles.
Low-Maintenance.
Conquer hair and debris with JawScrapers design. Shark-tooth blades strip away tangles for an uninterrupted, smooth clean.
Tangle Rate¹⁴
Edge-to-Edge Cleaning: From Baseboards to Corners
Dust tends to accumulate along walls and corners. Achieves 0mm¹⁵ edge-to-edge cleaning, helping clean along walls and corners.
FlatReach 2.0
Cleans Low Areas with Ease
The body tilts smoothly to a full 180°, maintaining suction even when completely flat. At just 12.5 cm (4.9 in) high¹⁶, it glides easily under furniture such as beds and couches / sofas.
12.5 cm
Body Height
180°
Lay Flat
Auto Detergent Dispenser
Smarter for Superior Cleaning
Enjoy up to 30 days¹⁷ of cleaning with a single detergent refill, as the auto dispenser precisely releases detergent as needed. *
Mighty Suction, Dust-Free Living
Sweep Dust Away in an Instant
Powerful suction paired with a unique adaptive brush delivers deep cleaning for floors and carpets, leaving them spotless and refreshed.
  • 120,000 RPM¹⁸
    High-Speed Motor
  • 25,000 Pa⁹ / 130 AW¹⁹
    Suction Power
Green Light Illumination
Shine the Light on Hidden Dust
Emitted from the brush head, the green light reveals dust and fine particles that are barely visible in natural light on the floor.
9-Cone Cyclonic Technology
Efficient Dust Separation, Long-Lasting Suction
The 9-cone cyclonic system generates powerful centrifugal force to separate dust from the airflow before it reaches the filter, helping reduce clogging and maintain strong suction over time.
Filter Rate²⁰
5-layer Noise Reduction System
Less Noise Interference
≤ 73dB(A)²¹
Under ECO Mode
Zero Hair Entanglement
hair tangle rate²² with unique adaptive brush
*Results may vary depending on the surface being cleaned.
Click, Drop, Clean
One-click dustbin release for convenient dust disposal and thorough interior cleaning.
Unlock unparalleled cleanliness with intelligent high-temperature self-washing and drying. The omni-sealed dock optimizes drying, while smart technology anticipates the self-cleaning needs of your Roborock F25 Pro Turbo Combo. Advanced solid-liquid-air separation technology helps deliver a thorough clean every time.
95 ℃
High-Temperature Self-Washing²³
and Hot-Air Drying²⁴
5 min
Fast Drying²⁵
>99.99%²⁶
Handles the Mess, So You Don’t Have to.
Featuring a detachable wet-and-dry separation module, the dirty water tank keeps solids and liquids apart for cleaner, easier disposal. No more clogging, dripping, or messy cleanups.
Moves as You Move
Smooth Maneuvers with Power-Enhanced SlideTech 2.0
Powered by dual brushless motors with independent wheel control, SlideTech 2.0 delivers ultra-smooth maneuverability with millisecond response times, enabling precise tight turns whether pushing or pulling.
Small Tweak, Big Improvements
Enhanced with a low water tank and 70° swivel design²⁷, it glides effortlessly around furniture and obstacles, delivering a smoother, more efficient clean.
Intuitive to Use and Flexible for Customization
Voice Alert
Receive timely notifications and updates via voice alerts, keeping you informed without checking the device.
Screen Display for Status Checks
Easily monitor device performance and settings via a clear display, with key status information available at a glance.
error
error
error
One-Touch App Customization
Easily tailor settings and preferences through app customization, creating a personalized cleaning experience.
error
error
error
Key Specs
Wet & Dry Vacuum Cleaner
263 ×242 ×1104 mm
Vacuum Cleaner with Dock
316 × 350 × 1163 mm
1. Based on testing carried out by TÜV SÜD on Staphylococcus aureus, Candida albicans and Escherichia coli under strong (MAX) mode, over 99.99 % of bacteria on the floor are effectively removed. Report No.: 704012409452-02. Actual results may vary according to the home environment.
2. Based on testing conducted by SGS, the bed brush removed over 99.99% of mites under test conditions. Report No.: SHES241102212775. Actual results may vary depending on the home environment.
3. Based on testing carried out by third-party Laboratory, In high mode, whole-machine filtration efficiency reached 99.99% for particles sized 0.30–10.0 μm. Report No.: 0363-26A-02A. Actual performance may vary depending on usage conditions and maintenance.
4. Based on internal testing conducted by the manufacturer using common household stains such as coffee stains, ketchup, mustard. Actual performance may vary depending on environmental conditions.
5. Based on internal testing conducted by the manufacturer, compared the average water delivery in AUTO Mode. Actual results may vary due to the usage and environment conditions.
6. Based on internal testing conducted by the manufacturer, compared with roller speed in AUTO Mode. Actual results may vary depending on usage and environmental conditions.
7. Based on internal testing conducted by the manufacturer, compared with suction performance in AUTO Mode. Actual results may vary depending on usage and environmental conditions.
8. Based on TÜV SÜD testing, after 60 minutes of on-tap scrub mode operation with push-and-pull movement on a solid wood floor, no blistering, bulging, or deformation occurred. Additionally, no visible scratches or color changes were detected. Report No.: 704012604029-00. Actual performance may vary depending on environmental conditions.
9. Based on internal testing conducted by the manufacturer. Actual performance may vary depending on environmental conditions.
10. Based on internal testing conducted by the manufacturer under on-tap scrub mode. Actual performance may vary depending on environmental conditions.
11. Based on internal testing conducted by the manufacturer. Actual performance may vary depending on environmental conditions.
12. Based on internal testing conducted by the manufacturer in ECO mode on a fully charged.
13. Based on internal testing conducted by the manufacturer, operating the machine in ECO mode with minimum suction power at a speed of 0.5 m/s. Actual results may vary depending on the home environment, level of cleanliness, cleaning habits, and other factors.
14. Based on SGS testing, the hair tangling rate is 0% when operating with 2,000 strands of 50 cm dry and wet hair across all four operating modes under controlled testing conditions. Report No.: SHES241002115876. Actual performance may vary depending on environmental conditions.
15. Based on internal testing conducted by the manufacturer. Edge cleaning performance applies to both left and right sides. Actual results may vary depending on environmental conditions.
16. Based on internal testing conducted by the manufacturer. Actual results may vary depending on environmental conditions.
17. Based on internal testing conducted by the manufacturer. A full cleaning solution tank provides up to 30 days of use under once-daily cleaning in a controlled test environment. Actual results may vary depending on home environment, level of cleanliness, cleaning habits, and other factors.
18. Based on third-party laboratory testing. Actual results may vary depending on environmental factors.
19. Based on internal testing carried out by the manufacturer. The maximum suction reaches up to 130 AW, which generates a suction power up to 25,000 Pa. Actual results may vary depending on environmental factors.
20. Based on testing conducted by third-party laboratory, on new filter samples in accordance with EN ISO 29463-5:2022. The test used KCl aerosol at a rated airflow of 43 m³/h and particle size ≥0.30 μm.
21. Based on internal testing conducted by the manufacturer. Actual results may vary depending on the home environment.
22. Based on testing carried out by TÜV SÜD, the average hair removal rate reaches 100.00% and left 0 hair entanglement on the brush surface. Report No.: 704012409503-03. Actual results may vary according to the home environment.
23. Based on internal testing conducted by the manufacturer. The stated 95°C refers to the temperature within the air duct, not the temperature of the water. Actual performance may vary depending on environmental conditions.
24. Based on internal testing conducted by the manufacturer. The stated 95°C refers to the temperature within the air duct. Actual results may vary depending on environmental factors.
25. Based on internal testing conducted by the manufacturer. Actual results may vary depending on environmental factors.
26. Based on TÜV SÜD testing of Staphylococcus aureus, Candida albicans, Klebsiella pneumoniae, and Escherichia coli under self-cleaning and drying mode, over 99.99% of bacteria on the floor were effectively eliminated. Report No.: 704012409452-02. Actual performance may vary depending on environmental conditions.
27. Based on internal testing conducted by the manufacturer. 70° steering refers to the combined rotation of both brush heads, each rotating at least 35°. Actual performance may vary depending on environmental conditions.
