Designed for complex homes, it delivers powerful vacuuming and deep mopping—while climbing thresholds, gliding under furniture, and adapting across carpets. Qrevo Edge 3 Pro knows where to go, what to avoid, and finishes the job on its own.
AdaptiLift Chassis 3.0
Powered by AdaptiLift Chassis 3.0 with a climbing arm, it lifts and climbs over high thresholds effortlessly—so cleaning doesn’t stop at boundaries.
4.5 cm + 4.3 cm
20,000+
Threshold Crossings Tested³
7.95 cm
Low-Clearance Access⁴
100,000+
Lift Cycles Tested⁵
36,000 Pa HyperForce Motor
Dual Anti-Tangle System
Designed to handle even long hair, the DuoDivide Main Brush and FlexiArm Arc Side Brush work together to prevent tangles and maintain continuous cleaning.
Enhanced Mopping Performance
30%
Less Water Residue¹⁰
14N
200 RPM
Spinning Speed¹²
Advanced Carpet Cleaning
FlexiArm Technology
Roborock’s FlexiArm Arc Side Brush and Edge Mopping System clean tightly along walls and into corners, while the extendable side brush reaches under toe-kick areas for more complete coverage.
Liftable Brush and Mops
Advanced Obstacle Avoidance
Powered by Reactive AI Obstacle Recognition, which combines structured light and an RGB camera, together with VertiBeam Lateral Obstacle Avoidance, it detects more obstacles near and far—even along walls and furniture—with minimal blind spots.
Uses up to 100°C hot water to loosen grease and stubborn residue for a more hygienic clean.
Up to
100℃
Hot-Water Mop Washing¹
Bacteria Removal Rate¹⁸
Roborock APP
The Brain Behind Every Clean
Carpet Cleaning
Roborock SmartPlan 3.0
Pet-Friendly Intelligence
Closer to Your Furry Friends
Automatic Pet Recognition
Pet Snaps
Search for the Pet
Video Call & Cruise
Everyday Features
Key Specs
Qrevo Edge 3 Pro
Qrevo Edge 3 Pro
Qrevo Edge 3 Pro
352*350*79.8 mm
402*494*450 mm
* Images and videos are for illustration purposes only and may not exactly represent the product. The app interface, feature availability, and navigation paths are subject to change without notice.
1. Based on internal testing conducted by the manufacturer. The heating module can heat water up to 100°C under standard atmospheric pressure (1 atm, 101.3 kPa) at room temperature. Actual results may vary depending on usage and environmental conditions.
4. The body height of the robot vacuum is 7.98 cm. Due to slight vertical flexibility in the front structural components, the robot may achieve limited passive compression when entering low-clearance spaces, allowing access down to 7.95 cm. However, please note that scraping may occur. Actual performance may vary depending on environmental conditions.
7. Based on internal testing, the hair tangling rate was 0% using 0.1 g hair samples at each tested hair length (20 cm, 30 cm, and 40 cm) across all five operating modes under controlled test conditions. Actual results may vary depending on environmental conditions.
8. Based on internal testing, the hair removal rate reached 100% using 0.1 g hair samples at each tested hair length (20 cm, 30 cm, and 40 cm) under controlled test conditions. Actual results may vary depending on environmental conditions.
9. Based on internal testing, the hair tangling rate was 0% using 0.1 g hair samples at each tested hair length (20 cm, 30 cm, and 40 cm) across all five operating modes under controlled test conditions. Actual results may vary depending on environmental conditions.
13. Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors. This feature is powered by Roborock’s AdaptiLift Chassis—the industry’s first mass-produced liftable chassis system with three-wheel control, launched in Q3 2024. The dynamic carpet-cleaning capability was officially introduced in Q3 2025.
16. Compared with the Roborock previous-generation model in the same Roborock product category under internal test conditions. Recognition accuracy may vary depending on environmental factors.
19. Based on internal testing carried out by the manufacturer, the air at the base's outlet during drying can be heated up to 55°C under standard room temperature. Actual temperatures may vary due to environmental factors.
21. These carpet cleaning settings must be manually enabled and selected in the Roborock app. This feature is applicable to household carpets with pile heights of 3 cm or below, which covers the majority of carpets used in typical homes.
