7.98 cm Ultra-Slim Design
Cleans beneath furniture with ease.
FlexiArm Technology
Reaches deep into corners for maximum coverage.
Dual Anti-Tangle System
Keeps brushes clear for smooth cleaning.
Multifunctional Dock 3.0
75°C hot water2 keeps mops and dock hygienic.
18,500Pa HyperForce Suction1
Deep suction for carpets and hard floors.
Identifies and avoids 108 types of obstacles in real time.
FlexiArm Technology
At a sleek 7.98 cm, the Roborock Qrevo EdgeT effortlessly slips under sofas, cabinets, and beds, capturing hidden dust where others can't. Deep cleaning made easy, even in the hardest-to-reach spots.
100% Success Rate
Cleaning in Spaces ≥7.98cm High3
In Open Areas
Under Low Furniture
The LiDAR sensor stays elevated, offering 360° all-around scanning to create precise maps and chart the most efficient cleaning routes throughout your home.
The LiDAR sensor retracts automatically, shifting to a 100° rear field of view—optimized for tight spaces. This ensures smooth, accurate navigation, even in the most hard-to-reach areas.
The Upward Range Finder accurately measures overhead clearance in real-time, enabling the LiDAR to either retract or rise—ensuring smooth navigation in any environment.
The Top Contact Sensor detects overhead obstacles, preventing collisions and surface scratches by keeping the robot from entering spaces that are too tight.
Crafted for durability, the system undergoes rigorous testing to withstand tens of thousands of cycles4, guaranteeing reliable, rock-solid performance you can count on.
Experience Roborock's groundbreaking dual anti-tangle system, featuring a main and side brush engineered to tackle everything from pet fur to 40cm-long hair. Enjoy a hassle-free clean every time.
DuoDivide Main Brush
Hair Tangling Rate5
Hair Removal Rate6
FlexiArm Arc Side Brush
Hair Tangling Rate7
18,500 Pa HyperForce Suction
The Roborock Qrevo EdgeT delivers impressive cleaning power with 18,500 Pa HyperForce suction1, ensuring no debris stands a chance.
FlexiArm Technology
Roborock's exclusive FlexiArm Arc Side Brush and Edge Mopping System offers supreme thorough cleaning coverage, leaving behind no dirt by eliminating blind spots.
Edge and Corner Coverage8
0mm
Along the Edge and Corner8
Liftable Spinning Mops
Experience effortless deep cleaning as the dual mops rotate with up to 8N of downward pressure9 and consistent humidity, effectively lifting and removing stains.
8N Max.
Downward Mopping Pressure9
200RPM
Spinning Speed10
10mm
Mop Lifting11
The upgraded Multifunctional Dock 3.0 offers 75°C hot water mop washing and self-cleaning, delivering a truly hands-free experience that keeps your robot fresh and ready for every clean.
75°C Hot Water
Mop Washing2
75°C Hot Water
Dock Self-Cleaning12
Intelligent
Dirt Detection
45°C Warm
Air Drying
Auto Dust
Emptying
Auto Tank
Refilling
Effortlessly remove stubborn stains and grease with 75°C hot water2, ensuring your mops are thoroughly cleaned for consistently superior mopping performance.
Bacteria Removal Rate13
Equipped with structured light and an RGB camera, the robot detects and avoids 108 types of objects16. It efficiently navigates around obstacles, reducing the need for manual intervention in both well-lit and dim environments.
108Types
of objects Recognizable
Roborock SmartPlan 2.0
Haven’t cleaned in a while? Deep clean boost. Kitchen? Mop re-wash before moving on. Roborock SmartPlan 2.0 customizes your cleaning based on your habits, room types, and floor materials for efficient cleaning tailored to your home.
Automatically deep cleans rooms that have not been cleaned for a long time
Lowers power and reduces noise during Do-Not-Disturb periods
Re-washes the mops right after cleaning kitchens and bathrooms or after a second mopping pass
Pet-Friendly
Video Call
Automatic Pet Recognition
Pet Snaps
Search for the Pet
Matter Protocol
Third-Party Voice Control
Launcher Widgets
Apple Watch App
Featuring the DuoDivide Main Brush and FlexiArm Arc Side Brush for tangle-free cleaning.
Industry-First17 AdaptiLift Chassis
Smoothly clears thresholds up to 4cm18 for seamless movement.
18,500 Pa HyperForce Suction1
Delivers unmatched suction power for a deep and effective clean.
FlexiArm Technology
Features an extendable side brush and mop for precise cleaning in every corner.
Enhanced 75°C hot water2 mop washing for a deep, hygienic clean of your mops and floors.
Powerful HyperForce Suction
*Suction power values may vary by country or region. Please refer to information from your purchase channel for accurate details.
FlexiArm Technology
1. Based on internal testing carried out by the manufacturer according to IEC 62885-2:2021/5.11 standards, using Max+ mode with a full battery.
2. Based on internal testing carried out by the manufacturer, the water at the clean water dispensers of the base can be heated up to 75°C under standard room temperature. The actual temperature will vary due to environmental factors.
5. Certified No.PT/24/GEN/0453/2 by SGS. Actual results may vary according to the home environment.
6. Certified No.PT/24/GEN/0454/3 by SGS. Actual results may vary according to the home environment.
7. Certified No.PT/24/GEN/0455/2 by SGS. Actual results may vary according to the home environment.
8. Certified No.0217010051 by TÜV Rheinland. Actual coverage and distance may vary according to the home environment.
10. Based on internal testing carried out by the manufacturer, when selecting extreme water flow in custom mode, the mops can spin at a maximum speed of 200 rpm. Actual results may vary depending on environmental factors.
11. Based on internal testing carried out by the manufacturer, the mop modules can be lifted up to 10mm.
12. Based on internal testing carried out by the manufacturer, the water at the clean water dispensers of the base can be heated up to 75°C under standard room temperature. The hot water cleans the cleaning tray during mop washing. The actual temperature will vary due to environmental factors.
13. Based on testing carried out by TÜV Rheinland on Staphylococcus aureus and Escherichia coli under default self-cleaning mode, over 99.99% of bacteria on the spinning mops are effectively removed. Certification ID: 0000088126. Actual results may vary according to the home environment.
14. Based on internal testing carried out by the manufacturer, the air at the base's outlet during drying can be heated up to 45°C under standard room temperature. The actual temperature may vary due to environmental factors.
15. Based on internal testing carried out by the manufacturer. Actual emptying intervals will depend on use habits and environmental factors.
16. Based on internal testing carried out by the manufacturer, the robot vacuum can see and bypass objects down to as small as 5cm wide and 3cm tall. Recognition accuracy may vary depending on environmental factors.
17. Roborock was the first in the robot vacuum industry to mass-produce a product featuring a liftable chassis system with three-wheel control, officially launching this technology in Q3 2024.
18. Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors.
