Qrevo 2 Flow
Let It Roll.
The Qrevo 2 Flow combines powerful suction with advanced roller mopping for effortless whole-home cleaning. SpiraFlow 2.0 keeps the roller fresh throughout every clean, while an ultra-slim design reaches beneath low furniture. With automated mop washing, drying, and detergent dispensing, the all-in-one dock leaves you with less to do—and more time for yourself.
Meet the Next Generation of Floor Washing.
SpiraFlow 2.0 Pressurized Self-Cleaning System
Tackles Sticky Messes in One Pass³.
  • Ketchup
  • Muddy Pet Stains
  • Soy Sauce Spills
  • Coffee Spills
2x
Pressurized Clean Water Outlets⁴
240 RPM
High-Speed Rotation⁵
2.5x
Downward Mopping Pressure⁶
Bacteria Removal Rate⁷
Freshness You Can Feel Underfoot.
270 mm
High-Density Antibacterial Roller⁸
Helps reduce water spots by
30%⁹
Suitable for everyday hard floors.
  • Wood Floors
  • Tile
  • Marble
Incredibly slim.
Surprisingly powerful.
More Power for Your Floors. More Time for You.
Max Digital Motor Power¹
  • 100%
    Hair Pickup Rate on Floor¹⁰
  • 15% Higher
    Pet Hair Pickup Rate¹¹
Deeper into Corners.
Closer to Edges.
The Reversible Side Brush sweeps debris out of corners, while the Edge-Adaptive Roller Mop extends to clean closer to edges, helping clean along walls and skirting boards and around furniture corners with less effort.
30% More
Corner Coverage¹²
Edge Sweeping¹³
<10 mm
Edge-Close Mopping¹⁴
Up to 44 mm
Roller Extension¹⁵
8.98 cm Ultra-Slim Design
Built to Clean Deeper.
Success Rate
Smooth Navigation,
Even Down Low.
100,000+
Lift Cycles Tested¹⁷
Zero Tangles.
Effortless Upkeep.
Dual Anti-Tangle System
DuoDivide Main Brush
Hair Tangling Rate²
Dual Lifting Side Brushes
Hair Tangling Rate²
*The right side brush structure may vary slightly depending on the production batch.
Simply Better in Every Detail.
Easy-Rinse Dirty Water Tank
The redesigned dirty water tank features a simplified internal structure that makes rinsing easier and helps reduce residue buildup. An upgraded handle also makes the tank easier to empty.
75° Tiltable Roller
Tilts up to 75° for easier roller removal and deep cleaning.
Meet the All-in-One Dock That Handles It All.
Multifunctional Dock
All-New Pressurized Self-Cleaning
The all-new system continuously jets clean water from the dock to refresh the roller, while dirty water is collected separately in the robot’s dirty water tank. With minimal water remaining in the cleaning tray, clean and dirty water stay separated, helping keep each mop wash cleaner, fresher, and more hygienic.
Bacteria Removal Rate¹⁸
10%
Less Water Usage¹⁹
Auto Detergent Dispensing
Paired with pressurized mop washing, the dock automatically dispenses cleaning solution for a more thorough, fresher mop wash. No measuring or manual dosing before every cycle—just better cleaning with less effort.
Other Features
High Temperature Self-Cleaning²⁰
With automatic high-temperature self-cleaning at up to 75°C, the roller mop is washed more effectively with every cycle, helping reduce dirt and residue for fresher, more hygienic floor cleaning.
63°C Warm Air Drying
Dries the roller mop and dock base thoroughly with 63°C warm air²¹, helping prevent mold growth and unpleasant odors.
Auto-Refilling
Automatically refills the robot’s water tank when needed.
Auto Dust-Emptying
Provides up to 65 days²² without manual emptying.
Detachable Dock Base
A fully detachable dock base makes washing easier when needed.
See, Sense, and Steer Clear
Powered by structured light, the robot efficiently detects obstacles. Even in a cluttered room with items scattered across the floor, it can effortlessly detect and navigate around them.
Your Privacy,
Our Priority.
error
The Brain Behind Every Clean
Carpet Cleaning
Want to deep clean carpets or skip them entirely? One tap is all it takes. Your robot adapts automatically—boosting suction on carpets with the mop lifted or following precise edge-cleaning paths to avoid rugs and keep them dry*. You're in control of every room, every rug, every time²³.
*These carpet cleaning settings must be manually enabled in the Roborock app.
Roborock SmartPlan 3.0
One Tap. Let Smart Take Over.
After room types are selected, Roborock SmartPlan 3.0 learns your cleaning habits, and selects the optimal cleaning strategy—boosting suction when needed, rewashing the mop as required, and reducing power to minimize noise during Do-Not-Disturb periods.
Everyday Features
Temporary Cleaning
‘Temp Cleaning’ tackles unexpected spills instantly without interrupting your current schedule, while ‘Temp Skip’ lets you temporarily avoid specific areas as needed.
Custom Routines
Customize your cleaning routine in the app by setting the time, cleaning mode, and rooms. The robot will then start cleaning automatically.
For hard-to-reach areas, such as spaces under chairs and tables, the robot can detect potential problem areas and suggest setting them as ‘No-Go Zones’ to help prevent it from getting stuck.
Clean Beyond Curtains
Third-Party Control
Matter supported. Automate routines and control all your devices from a single platform. Also compatible with Alexa, Siri, and Google Home.
Specs
Qrevo 2 Flow
Qrevo 2 Flow
Qrevo 2 Flow
352*353*89.8 mm
402*470*451 mm
* Images and videos are for illustrative purposes only and may not precisely represent the actual products.
1. This figure refers to the performance of the digital motor based on Roborock internal testing. Using air performance testing equipment to test the static pressure of a single fan under the condition of 0mm orifice. The maximum static pressure of the digital motor unit under 0mm orifice can reach up to 32kPa. Actual results may vary depending on product configuration and usage conditions.
2. Based on internal testing, the hair tangling rate is 0% in Standard Cleaning Mode when operating with 0.1 g of hair at lengths of 20 cm, 30 cm, and 40 cm, respectively, under controlled testing conditions. Actual performance may vary depending on environmental conditions.
3. Based on internal testing conducted by the manufacturer, the roller mop achieved up to a 100% removal rate for coffee spills, soy sauce, ketchup, and wet mud stains in a single pass in Standard Vacuum-and-Mop Mode.
4. Compared to SpiraFlow 1.0 with 8 hydration points. Based on internal manufacturer testing. Actual results may vary depending on environmental conditions.
5. Based on internal testing conducted by the manufacturer, the roller mop can reach a maximum rotational speed of 240 RPM when the water flow is set to High. Actual performance may vary depending on environmental conditions.
6. Compared to the Roborock Qrevo Curv, which delivers up to 6 N of mopping pressure, the current model delivers up to 15 N, based on internal testing conducted by the manufacturer. Actual performance may vary depending on the home environment.
7. Based on testing carried out by TÜV SÜD in Sweep-Mop Mode (suction: Max; water flow: 16; cleaning efficiency: Fine), over 99.99% of Escherichia coli, Staphylococcus aureus, and Candida albicans on the roller mop were effectively removed. Certification No. 704012602394-00. Actual results may vary depending on the home environment.
8. Tested by SGS in accordance with GB 21551.2-2024, Antibacterial and Cleaning Function for Household Appliances, the antibacterial rate against Klebsiella pneumoniae ATCC 4352 reached over 99.99% (Test Report No. ASH26-0017316-01A1). Actual results may vary depending on the home environment.
9. Compared to the performance of the Qrevo Curv 2 Flow. Based on internal testing conducted by the manufacturer. Actual results may vary depending on environmental factors.
10. Based on internal testing, the hair removal rate is 100% when operating with 0.1 g of hair at lengths of 20 cm, 30 cm, and 40 cm, respectively, in Vacuum-Only Mode, under controlled testing conditions. Actual performance may vary depending on environmental conditions.
11. Compared with the Roborock Qrevo Curv. Based on internal testing using 1 g of cat hair on hard floors. Actual performance may vary depending on the home environment.
12. Compared to the inside-corner coverage performance of the Qrevo Curv 2 Flow. Based on internal testing conducted by the manufacturer. Actual results may vary depending on environmental factors.
14. Based on internal testing conducted by the manufacturer. Actual results may vary depending on environmental factors.
15. Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors.
16. The robot vacuum has a body height of 8.98 cm. Due to slight vertical flexibility in the front structural components, it may undergo limited passive compression when entering low-clearance spaces, allowing it to access spaces as low as 8.98 cm. However, scraping may occur. Actual performance may vary depending on environmental conditions.
17. Based on internal testing conducted by the manufacturer. Actual results may vary depending on environmental factors.
18. Based on testing conducted by TÜV SÜD, over 99.99% of Escherichia coli and Staphylococcus aureus on the mop were eliminated after a complete self-cleaning cycle in Mop-Wash Mode, including soaking, high-temperature cleaning, and deep drying. Certification ID: 704012602394-00. Actual results may vary depending on environmental conditions and usage.
19. Compared to the water usage of the Qrevo Curv 2 Flow in Soaking Mode. Actual results may vary depending on environmental factors.
20. Based on internal testing conducted by the manufacturer. The stated temperature is measured at the internal heater output and does not refer to the mop-washing water temperature. Actual results may vary depending on usage and environmental conditions.
21. Based on internal testing conducted by the manufacturer. During drying, the air within the heating module can reach up to 63°C at standard room temperature. Actual results may vary depending on usage and environmental conditions.
22. Based on internal testing conducted by the manufacturer. Actual emptying intervals will depend on usage habits and environmental factors.
23. This feature is suitable for household carpets with pile heights of 3 cm or less, covering most carpets used in typical homes.
