Q5 Max+
Dual Roller, Mega Suction
5,500 Pa
Suction
DuoRoller
Brush
AUTOMATIC
Dust Emptying
VIDEO
SMART
Navigation
APP
Easy-to-Use
5,500 Pa
Suction
VIDEO
AUTOMATIC
Dust Emptying
APP
Easy-to-Use
SMART
Navigation
DuoRoller
Brush
Dual
Roller,
Mega
Suction
Dual
Roller,
Mega
Suction
Meet the Q5 Max+, your dirt and dust conqueror. With DuoRoller Brush and 5500 Pa suction power1, it effortlessly tackles cleaning challenges. Thanks to PreciSense LiDAR navigation, routes are optimized, while auto-emptying handles manual tasks.
*The golden version of this product is referred to as the Q5 DuoRoller+ on certain platforms.
Unleash the Power of Double Roller
The innovative DuoRoller Brush effectively lifts dirt, debris, and pet hair, providing thorough cleaning results while reducing hair tangling.
All-Rubber Brushes
5500 Pa Suction: Dirt Removal Made Powerful
5500 Pa Suction:
Benefit from efficient cleaning with Q5 Max+’s extreme suction power, which excels at capturing dust, debris, and dirt from various floor types no matter whether you have hardwood, tile, or carpet.
5,500 Pa
For Floors: Q5 Max+ cleans along the seams of hardwood floors, capturing cracks for better cleaning efficiency.
99%
For Carpets: Get spotless carpet care with the dual brush system, boasting a 99% hair pick-up rate.2
5,500 Pa
99%
Compatible with a 180ml water tank and a mop
*Sold Separately
Cleaning Oomph for Hours
Enjoy uninterrupted cleaning with the mighty 5200mAh battery and a spacious 770ml onboard dustbin. Q5 Max+ is prepared for cleaning marathons that last up to 4 hours.
770ml
Onboard Dustbin
240 min
Maximum Runtime3
350 sqm (3767 sqft)
Maximum Vacuuming Area3
Optimal Routes for Spotless Results
6x Faster
Mapping4
3D
Map Display
Multi-level
Mapping System5
Let the PreciSense LiDAR Navigation System take charge. It glides effortlessly across your home, mapping every inch with precision, and identifying the optimal cleaning routes.
Smart Suggestions for
No-Go Zones
Experience enhanced intelligence with the Q5 Max+, as it intuitively suggests No-Go Zones to keep your robot vacuum away from tight spots and prevent accidental falls down the stairs.
Hands-Free, Hassle-Free
7 WEEKS
Bid farewell to frequent manual emptying thanks to RockDock Plus compatibility. The 2.5L E12-rated dust bag saves you from emptying for up to 7 weeks while ensuring efficient filtration of dust and allergens, maintaining cleaner air quality in your home.6
Suction Power
Balanced
Route
Fast
Your Cleaning Preferences, Your Way
Custom Cleaning at Your Command
Personalize your cleaning routine with Custom Cleaning. Set a time, cleaning mode, and the rooms to be cleaned, and the process will start automatically.
Fast Cleaning
Experience 30% faster cleaning by selecting the fast cleaning route on the App as needed, saving you precious time.7
Voice Control at Your Command
Send the vacuum home
Start cleaning the living room
Start the vacuum
Forget about manual commands and embrace voice control. Q5 Max+ syncs seamlessly with Alexa, Apple Siri, and Google Home, so all you have to do is say the magic word. By simply using your voice you can initiate cleaning or adjust settings effortlessly.
  • Customizable App Features
  • Scratchsafe Wheels and Brushes
  • Sensient Sensor Array
  • Adaptive Route Algorithms
  • Child Lock
  • Off-Peak Charging
Q5 Max+
Robot vacuum
353*350*96.5 mm
305*440*425 mm
1. Based on internal testing carried out by the manufacturer according to IEC 62885-2:2021/5.11 standards, using Max+ mode with a full battery.
2. Based on internal testing carried out by the manufacturer using Max+ mode. Actual results may vary according to the home environment.
4. Based on internal testing using Quick Mapping mode. The mapping efficiency of Quick Mapping mode is 6 times faster compared to Clean&Mapping mode. Actual results may vary according to the home environment.
5. Up to four levels of floors supported.
7. Compared to standard cleaning route mode. Actual results may vary according to the home environment.
