Roborock Qrevo Plus
Get the Edges
Available in 2 Options
Qrevo Plus
Manual Water Tank Replacement
Flexible Dock Placement
Qrevo Plus with Refill and Drainage System
Automated Water Replacement
Pre-check for Installation Required
Learn more
Learn more
FlexiArm Design Edge Mopping System
Leave no edge untouched.
FlexiArm Design mop features an extendable design that automatically extends when edges are detected, even around the legs of tables and chairs.
98.8%
edge coverage1
1.85 mm
along the edge1
Cleaning around the legs of tables and chairs
Cleaning near the dock
Dual Liftable Spinning Mops
Mops as if you did.
With dual liftable spinning mops, Roborock Qrevo Plus is designed to tackle stubborn stains as if you were mopping by yourself, whether it's smooth tiles or rough surfaces.
200 RPM
maximum mopping speed2
Dual mopping pads spin up to 200 revolutions per minute, removing stubborn stains, and mimicking hand-mop results.
10mm
mopping module lifting3
The mopping module is able to lift 10 mm to avoid damping short pile carpet while cleaning.
30 Levels
of constant dampness water flow4
You can finely adjust water flow in detailed 30 levels to meet needs of different floor types and humidity conditions.
Lift mops to avoid cross-contamination.
Mops will be lifted when returning for charging or washing, or when resuming mopping after washing.
Lift mops to ensure ventilation.
While charging, mops are lifted to maintain ventilation, preventing molds and bad smells.
HyperForce Cleaning Power
Root out hair from crevices and carpets.
With its impressive 7000 Pa suction, Roborock Qrevo Plus is designed to remove hair and debris in floor crevices and deep in carpets. When operating at maximum suction, the main brush speed will be increased by 10% compared to the standard mode for optimal efficiency.
7000Pa
Extreme Suction5
All-Rubber Anti-Tangle Brush
Less tangle.
Less trouble.
Roborock SmartPlan
Say goodbye to
complicated settings.
Roborock SmartPlan tailors the optimal cleaning program according to your room type6. If you have set different floor types, it will adapt its cleaning strategies accordingly.
Study Room Quiet vac. Standard mop.
Bedroom Quiet vac. Gentle mop.
Living Room Standard vac. Standard mop.
Clean bedrooms before bathrooms and kitchen.
Wash mops right after finishing each room.
Prefer complete control?
No problem.
Temporary Cleaning
Not cleaned thoroughly? Clean again.
During cleaning, if any area is not well cleaned, you can direct the robot to clean it again. Once finished, it will resume its original task.
Custom Cleaning Routines
Shortcut your preferences.
Save the operations you use frequently as shortcuts. Activate them anytime in the Roborock App or home screen widgets.
Flexible Schedules
When and how to clean? It's your call.
You can schedule cleaning by day, by hour, by room, by mode, and even by custom routines.
Child Lock
Safety matters.
Once the child lock is enabled, the physical buttons will be locked when the robot is stationary.
Temporary Cleaning
Flexible Schedules
Child Lock
Safety matters.
Start cleaning any way you like.
Launcher Widgets
One-click to access custom cleaning routines, start cleaning, and more.
Apple Watch App
Start cleaning on your Apple Watch without reaching out for your phone.
Charge in off-peak time.
Charge in
off-peak time.
For Floors
Clean along
floor directions.
The Roborock Qrevo Plus cleans along the direction of preset tiles to better remove hair and dust from crevices, while also reducing the noise from the main brush rubbing against floor cracks.7
For Carpets
Care for your
carpets as you do.
Different strategies can be set separately on each individual carpet.8
High Pile Carpets
Choose to avoid
Entrance Carpets
Go across
Carpet Boost
Boost suction power when on carpets.
Deep Carpet Cleaning
Clean your carpet twice for each room.
Vacuum Carpet First
Vacuum carpet first with a dry mop. Then start to mop.
Multifunctional Dock
Now you can rest.
With no compromise, this fully automated dock empties and washes the robot, so you can focus on what truly matters.
Mop Self-Washing
Warm Air Drying
Auto Tank Refilling
Detachable Dock Base
30% Faster Charging
Mop Self-Washing
Warm Air Drying
Auto Tank Refilling
30% Faster Charging
Mop Self-Washing
Cleaner mop.
Cleaner floor.
Multifunctional dock emulates the cleaning process of a washing machine for mops, featuring a slow pre-wash, a medium rinse, and a high-speed spin drying. It dynamically adjusts speed and water flow for high efficiency and convenience.
3-Stage
dynamic cleaning process
Warm Air Drying
Silently. Safely. Evenly.
45dB(A)
low drying noise9
While drying, noise levels are minimized to as low as 45dB(A), similar to the ambient noise level in a library.
3x Safety Protections
constant temperature drying
The multifunctional dock ensures safe drying with a thermostat, a fuse, and software control.
15-Minute
rotation interval to dry evenly
During drying, the mop automatically rotates once every 15 minutes, ensuring more uniform drying of the mop.
Automatically adjusts
dust emptying based
on hair buildup.
Upon detecting a large amount of hair, the robot will increase its auto-empty frequency to avoid the dustbin being full when returning to charge.10
The dust bag is designed with a pull-to-seal feature, boasting a sturdy handle that seals automatically upon lifting. This not only keeps hands clean but also prevents swelling or bursting when absorbing water.
7 Weeks
without manual emptying11
By automatically vacuuming dirt back into the dock, you can enjoy over 7 weeks of hands-free cleanliness.
99.9%
pollen filtration rate12
Certified by SGS, the dock can remove up to 99.9% of pollen particles in auto dust emptying.
Auto Tank Refilling
Mops up to 330sqm constant damp mopping per fill.13
The multifunctional dock refills the robot water tank automatically during cleanup whenever the water level is low. It can mop up to 330 sqm before you need to fill the clear water tank manually.
Up to
330sqm
mopping coverage on a single fill
Say goodbye to buildup of mud.
The entire dock base can be removed for thorough cleaning, reducing the buildup of mud and dirt over time. The upgraded large filter helps further reduce clogging.
30% Faster Charging
Resume cleaning faster.
Quickly resume cleaning by charging 30% faster than before.14
Ready to avoid troubles.
Every time.
Ready to avoid
troubles. Every time.
Powered by structured light, the Roborock Qrevo Plus is ready to detect and navigate around obstacles effortlessly, even in cluttered rooms with items scattered on the floor.
Smart Suggestions for
No-Go Zones
Smart Suggestions
for No-Go Zones
For easy-to-get-stuck places like below chairs and tables, the Roborock Qrevo Plus can detect and suggest them as 'No-Go Zones' to avoid getting stuck.
Privacy
Your privacy matters. As always.
Your privacy matters to Roborock as how it matters to you. Roborock Qrevo Plus is certified by TUV Rheinland to comply with ETSI EN 303 645.16
Roborock Qrevo Plus
350 * 353 * 96.5 mm
340 * 487 * 521 mm
Roborock Qrevo Plus with
350 * 353 * 96.5 mm
340 * 487 * 405 mm
  • Customizable App Features
  • Sensient Sensor Array
  • Adaptive Route Algorithms
  • Quiet Cleaning
  • Washable E11 Rated Air Filter
Sign up for product availability notifications, exclusive offers, campaigns and more.
1.Certified by TUV Rheinland. Certification ID: 1111277404
2. Based on Roborock internal testing, selecting extreme water flow in custom mode. Actual results may vary depending on usage conditions.
3.Based on Roborock internal testing, the mopping modules can be lifted up to 10mm. Actual results may vary depending on usage conditions.
4.Available in Roborock App with manual settings.
5.Based on Roborock internal testing under Max+ mode with a full battery according to IEC 62885-2:2021/5.11 standards. Actual results may vary depending on usage conditions.
6.Room types need to be set manually in Roborock App. The actual sweeping and mopping mode is automatically determined based on the home environment and historical cleaning behavior, and the actual cleaning mode shall prevail.
7.The "Clean Along Floor Direction" function needs to be set manually in Roborock App. The actual settings may vary depending on the app version.
8.Carpet cleaning strategies need be set manually in Roborock App.
9.Based on Roborock internal testing. Actual results may vary depending on usage conditions.
10.To achieve intelligent auto-empty, auto-empty frequency needs to be set to High on APP.
11.Based on Roborock internal testing, actual emptying intervals may vary depending on cleanliness conditions.
12.Certification No. SHFT230300005371 by SGS Testing. Actual results may vary depending on usage conditions.
13.Based on Roborock internal testing. Actual results may vary depending on environmental conditions.
14.Compared to the Roborock S7. Based on Roborock internal testing. Actual results may vary according to the home environment.
15.Based on Roborock internal testing compared to Clean & Mapping mode. Actual results may vary depending on environmental conditions.
16.Certified by TUV Rheinland to comply with ETSI EN 303 645. Certification ID: 1111265626
Take hands-free to
the next level.
On top of the maintenance-free dock features of the Roborock Qrevo Plus, we introduce a refill and drainage variant, taking your hands-free cleaning even further.
Auto Water Refill and Drain
Check Your Environment
Strong Wi-Fi coverage
Avoid direct sunlight
and humid environments
Installation Requirements
  • Maintain a space of approximately 41cm in height, 40cmin length, and 120cm in width.
  • Before installation, disconnect the power supply of the dock.Turn off the main water supply switch, faucet switch, or angle valve switch in the house. Drain any remaining water from the pipes, connect the water lines, and ensure no leaks before powering on.
Auto Detergent Dispenser
550 ml
Detergent Tank Size
Compact Design
*Products with a Refill and Drainage system are only available in certain regions and countries
