Treat yourself to crisp, just-mopped floors every day with S5 Max. Engineered for a seamless automated mopping, it has a super-sized water tank, precision water control, virtual no-mop zones, and more. Combined with precision laser mapping, advanced navigation, and intense vacuum suction, it makes spotless floors easier than ever. All you need to do is set it and get on with living.
S5 Max
Every day mopping made easy
Watch the Video
Purchase Now
From Business Insider 2019 © Insider, Inc. All rights reserved.
The CES Innovation Awards are based upon descriptive materials submitted to the judges. CTA did not verify the accuracy of any submission or of any claims made and did not test the item to which the award was given
Complete mopping convenience
Engineered to make mopping effortless
Precision water control
Choose the right amount for different floors
Virtual barriers
No-mop, and No-go zones for added control
Powerful suction
Draw up dirt, even from deep in carpets
Total App control
Pre-set everything from schedules to power
Make morning messes one less thing to worry about. Sweep crumbs and coffee grounds to the floor and head out the door. Set S5 Max to clean up when you’re gone and it can head straight to the kitchen and start a combined vacuum and mop to leave your floors spotless. Use no-mop zones, and it’ll even navigate around any carpets you’ve got along the way.
Keep your hardwood floors gleaming with zero effort. Fill up the S5 Max water tank and enjoy days of sparkling just-mopped floors before it needs refilling. No-mop zones keep carpets dry and safe, while optimized pathfinding algorithms and corner optimized cleaning finds the fastest route to cover every bit of your floor without missing even a sliver.
Time and lax cleaning dull the color of carpets. Bring yours back to vibrancy with S5 Max. Its 0.8in (2cm) climbing ability gives it the reach to clamber onto most carpets. Once there, it cranks suction up to full to pull dirt from deep in the carpet fibers. Make a bigger impact using zone-cleaning, to send the S5 Max on multiple loops of a single carpet with just a few taps.
Battery life
Supersized Lithium-Ion battery means up to 3-hours of non-stop cleaning2
Voice assistance
Your voice is all you need to start and stop a cleanup.
Easy maintenance
Quickly maintain or swap out parts to keep S5 Max cleaning at 100%
1. Based on internal testing carried out on hard floors with a full water tank, full battery, and low water flow. Actual results may vary, depending on the room characteristics. Range is an estimate based on the assumption that 20% of the area is covered by furniture and will not need to be mopped
2. Based on internal testing carried out by the manufacturer in Quiet mode with a full battery and with no mop system attached.
