            Eliminate both wet and dry messes in a single sweep with the Dyad Air, and enjoy an effortless cleaning experience that requires minimal maintenance.
                With unbelievable 17,000 Pa1 suction power, all messes, wet or dry, are removed easily, leaving behind the cleanest floor.
                    Exceptional
                      3 mm
                      3 mm
Edge Cleaning
The Dyad Air ensures unparalleled cleanliness right to the edges, thanks to its remarkable ability to handle margins of less than 3mm2.
                    Convenient Cleaning with
                      DirTect
                      DirTect
                    Smart Sensor
Automatically adjusts its cleaning power and water flow for a perfect clean when detecting how dirty the floor is. The on-screen LED indicator tells you where the dirt is so you know where to focus.
                  Self-Cleaning
Prepare to be amazed as the roller transforms from grimy to pristine in an instant, all with a simple press of the button. The bi-directional alternating scrubbing ensures that over 99%3 of dirt is eliminated from your roller, guaranteeing a spotless finish.
Self-Drying
The roller is dried automatically with noiseless drying mode, which means there won't be lingering odors and you can enjoy the peaceful ambiance.
                Self-Cleaning
                Self-Drying
                    App App Connectivity
Easily connects to the Roborock App for your convenience. Need to use the Self-Cleaning & Drying System? Need to change the cleaning mode? These options (and more) are a tap away.
                Voice Voice Alerts
Just Roll With It Roll With It
With a lightweight design of just 4.1 kg, the Dyad Air glides effortlessly across your floor, making cleaning easier for you.
Comparison
Comparison
Dyad Air vs Dyad Pro vs Dyad Pro Combo
Single Roller
3mm Edge Cleaning
DirTect Smart Sensor
Self-Cleaning and Drying System
App Connectivity
50 min Runtime
Multi-Rollers
1mm Edge Cleaning
App Connectivity
43 min Runtime
5-in-1 Combo
Multi-Rollers
1mm Edge Cleaning
App Connectivity
43 min Runtime (Wet Dry Vacuum)
60 min Runtime (Handvac)
2. Based on internal Roborock tests, roller approached 3mm to the edges of the walls.
3. According to Roborock’s internal experiments conducted with dirt and cat hairs.
4. Based on internal testing using Eco mode. Actual results may vary depending on environmental factors.
