Zeo Lite
Zeo Lite
Rolling with Confidence
Introducing Zeo Lite, the all-in-one solution for all your washing and drying needs, designed to provide unparalleled convenience and cleanliness. With revolutionary Zeo-cycle drying technology, a self-maintenance system, and intelligent app control, you can roll with confidence.
Zeo-cycle Drying Technology
Gentle and Powerful Drying for Different Clothing Types
Roborock LintClear
Self-Cleaning System
Say Goodbye to Lint and Maintenance Hassles
Stubborn Stains Removal1 & Hygienic Cleaning
Clean Deeper than You Imagine
Auto Dosing
30 Days Maintenance-Free2 Experience with Optimal Detergent Usage
Stay Informed and Never Miss a Laundry Cycle
Roborock LintClear
All-in-One
Ultimate Convenience for
Ultimate Fabric Care
Large Capacity
10 kg
Washer
6 kg
Dryer
Time-Saving
1h3
1h Fast Washing & Drying
App Convenience
27 Modes
Wash and dry programs
Gently Dry. Brilliant Care.
Discover the power of Zeo-cycle drying technology, inspired by zeolite, which safeguards your clothes from shrinkage and damage while providing a brilliantly shiny finish without extreme heat.
Learn more about Zeo-cycle
Hygienic Cleaning
Clean Beyond the Naked Eye
Enjoy ultra cleanliness with anti-allergy and hygienic healthier cleaning results. Zeo Lite removes bacteria, mites, pet dander, pollen, and allergens4, making it perfect for families with pets.
DD Motor
Enhanced Performance, Minimized Concerns
Experience enhanced washing performance and improved durability with the belt-less design of the DD motor, guaranteeing superior and long-lasting results.
Roborock LintClear Self-Cleaning System5
Say Goodbye to Lint6
Collects lint and removes it from the filter automatically with a separate water line,
eliminating the need for manual cleaning.
Collects lint and removes it from the filter automatically with a separate water line, eliminating the need for manual cleaning.
Smart Auto Dosing
Get the Perfect Clean Every Time
Automatically dispenses detergent and softener based on the weight
of the clothes for a hands-free experience.
Automatically dispenses detergent and softener based on the weight of the clothes for a hands-free experience.
30 Days
Maintenance-Free
580mL
Detergent
420mL
Softener
More Functions and Features are a Tap Away
With 27 smart wash and dry modes program that are perfectly tailored to your washing/drying needs, your clothing will be cleaned flawlessly.
Mix
Quick
Eco
40-60
Silk
Down
Air
Refresh
Anti-
Allergen
Sanitize
Intensive
Gentle
Baby
Care
Sports
Bedding
Underwear
Season
and more...
Drum Clean
Effortlessly cleans the drum inside and out for a hassle-free washing experience.
Auto Washing
Auto Drying
Automatic Load Detection
Save Time, Save Energy
Automatically adjusts the amount of water and drying time according to the weight of the clothes, saving energy and time, while thoroughly washing and drying your clothing.
Add Garment
Wifi Controlled
Child Lock
Interior Light
Power Outage Memory
Firmware Upgrade
Smart Spray System
Stainless Steel Drum
Zeo Lite Dimensions
595 × 682 × 850 mm
Available in 2 colors
What is Zeo-cycle Drying Technology ?
Unlike traditional drying technology, Zeo-cycle drying technology works by effectively and efficiently capturing moisture from damp clothes without extreme heat thanks to zeolite's super water vapor absorption capacity.
Because of zeolite's unique structure, it posses a strong absorption capacity. The total surface area of zeolite in Zeo-cycle for water vapor absorption measures 288,000 square meters7, equivalent to 41,143 times its own area8. With the assistance of strong airflow, the entire surface area can be rapidly utilized in a minute, without requiring extreme heat, further enhancing the efficiency of drying clothes.
How does Zeo-cycle work?
Zeo-cycle is developed with a unique double air circulation path: The drying air path continuously circulates to absorb the humid air in the drum to zeolite. The dry air is then blown into the drum to continue dehumidifying the clothes.
The regeneration air path performs dehumidification treatment on the zeolite, reducing it to a dry state, and as a result, this restores the water absorption capacity of the zeolite.
Why Zeo-cycle ?
Did you know that drying clothes at high temperatures might not necessarily be better? Traditional condensation drying technology typically uses temperatures exceeding 80 degrees, or even 100 degrees. Such high temperatures can wear down or weaken fiber strength, causing irreversible damage to clothing, especially wool and silk. With Zeo-cycle, you won'thave to worry about the shrinkage, deformation or discoloration.
The ideal washing and drying temperature for woollen sweaters is between 30-40 degrees. With Zeo Lite's wool washing and drying mode, you can rest assured that the temperature is stabilized within this controllable range9, ensuring that your delicate garments are well taken care of.
zeo-one zeo-lite
STAY TUNED IN!
1. Certified under rule IEC 60456-2022, certified No.4840123157301 by TUV SUD.
2. Based on internal testing carried out by the manufacturer. Estimated based on the load of a three-member family and a washing frequency of once every two days. Individual results may vary.
3. Based on internal testing carried out by the manufacturer. The Quick (Wash & Dry) program takes just 1 hour to wash and dry loads of up to 1kg. Actual results may vary according to the fabric.
4. Certified under rule GCN CCB GR 060CS, certified No. Z2GCN 118006 0025 Rev. 01 by TUV SUD.
5. There have been updates to the Roborock LintClear System. The visual may display a prior version of this feature.
6. Lint refers to the lint from fabric, instead of cat hair or dog hair.
7. Based on internal testing carried out by the manufacturer.
8. Based on internal testing carried out by the manufacturer.
9. Based on internal testing carried out by the manufacturer.
